Poly over shellac?
Forum topic by Dogfisher posted 12-04-2015 10:27 PM 1058 views 0 times favorited 19 replies Add to Favorites Watch
View Dogfisher's profile
Dogfisher
11 posts in 819 days
12-04-2015 10:27 PM
Topic tags/keywords: question
I glued branch slices down on a plywood tabletop. I’ve shellaced them many times over. I just finished grouting in between the discs with sanded grout. The shellac is a bit too gummy for my taste. It can be dug into with a fingernail. How could I finish it off to give it a harder surface? Polyurethane? That would also be a nice finish over the grout.
-- RMiller, New Jersey, http://inflatus1.wix.com/rsmiller
19 replies so far
View bobasaurus's profile
bobasaurus
3377 posts in 3090 days
#1 posted 12-04-2015 10:31 PM
Is the shellac dewaxed? If so, pretty much any top coat should stick to it. Odd that the shellac is gummy, it’s always dried pretty hard on my projects (though I only use thin coats). You probably want to seal the grout with dewaxed shellac before any other finishes, just to make sure the topcoat sticks.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View shampeon's profile
shampeon
1775 posts in 2090 days
#2 posted 12-04-2015 11:22 PM
Uh oh. How old is the shellac? Expired shellac will turn gummy and take forever to dry. Good shellac will dry to the touch within minutes.
You can try periodically doing a coat of denatured alcohol over it over the course of a day. But if that doesn’t work, and the shellac is expired, you’re probably going to have to strip and start over.
Dogfisher
#3 posted 12-05-2015 12:27 AM
That could be. It’s not that old but there was also some grey flaky crap that came off of the bottom of the can. I could sand it down and put a different finish on it. The discs are proud of the grout so sanding should work. Plus grouting was my main reason for shellacing. Now that the grout is done, I can refinish it if necessary. Thanks.
View AlaskaGuy's profile
AlaskaGuy
3912 posts in 2216 days
#4 posted 12-05-2015 10:34 AM
How many coats of shellac did you use? When shellac is applied to thick it can alligator in a year or so.
View Tennessee's profile
Tennessee
2745 posts in 2421 days
#5 posted 12-05-2015 12:18 PM
By the way, stunning design!
Dogfisher
#6 posted 12-05-2015 01:14 PM
Wow I didn’t think about that. Maybe I should sand it off and poly the whole top instead?
And thank you.
4881 posts in 2400 days
#7 posted 12-05-2015 01:23 PM
Sanding shellac can be a PITA (clogs paper), and if it’s gummy it can be even worse. I agree with the points made above: the shellac does sound like it’s too old, and even if it isn’t shellac is a thin finish…you have almost certainly applied too much. I’d try to remove it by scraping or some other method. Whatever you choose to do, I wish you the best….it’s really a nice looking table.
View dhazelton's profile
dhazelton
2689 posts in 2203 days
#8 posted 12-05-2015 01:52 PM
Try wiping it with an alcohol soaked rag to see if it removes the bulk of it. May just turn into a mess though.
View Rick_M's profile
Rick_M
11119 posts in 2286 days
#9 posted 12-06-2015 06:07 AM
Before you create a big mess, if it’s still warm where you are, try setting the shellac in sunlight for a few hours and see if it hardens. This time of year where I am tends to be chilly and wet so finishes cure extra slow. Also if you put a lot of coats on quickly they will cure more slowly.
-- http://thewoodknack.blogspot.com/
Dogfisher
#10 posted 12-06-2015 12:52 PM
Will do thank you.
View gfadvm's profile
gfadvm
14940 posts in 2597 days
#11 posted 12-06-2015 03:29 PM
I applied too many coats of shellac to a project and had that soft/gummy feel. I put it in the sun for a few hours and came back to find bubbles the size of grapes!!!
116906 posts in 3484 days
#12 posted 12-06-2015 03:38 PM
I agree with dhazelton wiping it with denatured alcohol should get the bulk of it off and leave enough for almost any finish to cling to. The one thing I do wonder about is how well a top coat will cling to grout . I would apply just a little to some of the grouted area and make sure you get good results before doing the whole top,
Cool looking table
Rick_M
#13 posted 12-06-2015 03:57 PM
- gfadvm
You always have the weirdest stuff happen, lol.
Dogfisher
#14 posted 12-06-2015 04:34 PM
I think I might just leave it as is and see what happens. If a problem arises, I will address it then. Thanks for all the great advice! Now to paint the base and put it to use.
View ThomasChippendale's profile
ThomasChippendale
244 posts in 839 days
#15 posted 12-07-2015 01:48 AM
I think you are right, it will eventually harden and then you can coat with your preferred finish. I would be inclined to flood the surface with epoxy on such a project.
-- PJ
