Porch post to floor connection
Forum topic by Ben posted 12-03-2015 10:09 PM 503 views 0 times favorited 2 replies Add to Favorites Watch
View Ben's profile
Ben
372 posts in 2826 days
12-03-2015 10:09 PM
I’m redoing a neighbor’s porch. One detail that I’m always thinking about is the best way to connect the wood porch posts to the wood floor. On my porch, I used a piece of 5/4” Azek with some holes drilled through it, then ran a little Azek shoe molding around the post to cover the joint. Seems OK. But what about a situation where I don’t want the shoe molding?
I’ve looked at something like this: http://www.homedepot.com/p/OWT-Ornamental-Wood-Ties-6-in-x-6-in-Laredo-Sunset-Post-Base-Kit-56608/203597828. Seems a cool idea, but these posts are 4 3/4” square, so that’s out.
What would you guys do? Soak end grain in wood preservative, prime and paint, and stick it on the floor?
What about routing out a few little 1/4” wide/deep weep channels into the bottom of the post? Then prime/paint/install.
Thanks.
2 replies so far
View rwe2156's profile
rwe2156
2884 posts in 1449 days
#1 posted 12-03-2015 11:03 PM
Either use cedar or cypress or treated wood.
If its to be painted I would go with treated.
Any kind of post support will do if you want to go with ornamental its fine.
View dhazelton's profile
dhazelton
2756 posts in 2265 days
#2 posted 12-03-2015 11:25 PM
There are cast porch post bases out there, as opposed to using the galvanized Simpson bases, and they aren’t too bad looking. But I think if you have posts with tight grain you could put a huge bead of caulk around the perimeter and put some quarter round around it and it will outlast you and your neighbor.
