| Forum topic by alanealane | posted 755 days ago | 407 views | 0 times favorited | 9 replies | ![]() |
755 days ago |
I’ve read the other posts on lumber storage, but didn’t seem to find a satisfying answer to the issue of whether to store lumber vertically or horizontally. My lumber supplier does both, but they expect to get rid of the wood pretty fast. I buy the wood and may not use it for a few years. Will lumber bow if stood on end? I have a basement shop (and no barn, garage, or shed to store wood in) so floor space is at a premium. In Michigan, the winter leaves the basement quite dry and I don’t worry about moisture, and in the summer, I run a dehumidifier almost constantly. The climate in my shop is pretty well controlled—a comfortable 55 to 60 degrees all the time, and dry!! I think I could save lots of floor space by storing wood vertically. So let’s hear some pros and cons of each method. Should I stack the lumber or stand it up? Also: If I were to store horizontally, What are some pros and cons of mounting shelf brackets on the wooden structural pillars in my basement as opposed to mounting them to the outer walls where the studs rest on the concrete block wall? Is either practice wise? Thanks -- Lane Custom Guitars and Basses |
