Left hand, right hand
Forum topic by ArtCam posted 12-03-2015 04:42 PM 889 views 0 times favorited 16 replies Add to Favorites Watch
View ArtCam's profile
ArtCam
20 posts in 888 days
12-03-2015 04:42 PM
My big old aircraft carrier rigid tablesaw allows for the fence to be used on the left comfortably.
My new Kobalt table saw (outdoor summer saw). Has the optimal fence position and extension on the right.
Since I am right handed I feel a bit awkward with this setup….and…. my body has to face the wood directly.
So if I need to get out of the way slightly, then I need to use the weaker less adept hand: my left.
I am under the impression that most people, sorry lefties, are right handed. Any thoughts? and I hope I am clear on this.
Happy woodworking. Derek
16 replies so far
View Alexl's profile
Alexl
59 posts in 904 days
#1 posted 12-03-2015 04:54 PM
i am right handed and it feels backwards to use the fence on the left side. I guess it is just what you are used to?
16274 posts in 4181 days
#2 posted 12-03-2015 05:08 PM
I am left handed, but I agree with you. Having the fence (and my body) to the right of the blade while pushing with my left hand seems like the safe and natural way to go. But. like Alexi said, I guess it’s all what you get used to.
View PineChopper's profile
PineChopper
187 posts in 2160 days
#3 posted 12-03-2015 06:04 PM
I’m right handed and since I bought my first table saw in 1973, I’ve always had the fence on the right.
After all these years, having it on the left would feel awkward.
View SirIrb's profile
SirIrb
1239 posts in 1194 days
#4 posted 12-03-2015 06:30 PM
Think, guys. If a righty uses the fence on the left and learns to push with the left hand you will not have a problem learning to write with your left if you dedigit yourself. Duh.
My fence is 99% on the right. I am a righty. The only times you need to break this that I can contemplate is certain bevel cuts / bevel cuts that are not through cuts.
ArtCam
#5 posted 12-03-2015 06:51 PM
Yep: Its what you are used to. Especially after 20 years of using the fence on the left.
Thanks
Alexl
#6 posted 12-03-2015 06:57 PM
Thanks
- ArtCam
i am shocked that you have always used the fence on the left. I thought everyone used it on the right unless they absolutely needed it on the left of the blade. I have never seen a TS that has just as much or more fence capacity on the left than the right. I guess i live under a rock
View TheDane's profile
TheDane
5399 posts in 3626 days
#7 posted 12-03-2015 07:08 PM
I think it depends on the direction the blade tilts. Making bevel cuts on a saw with a right-tilt blade and the fence on the right can be dangerous and/or impossible.
View nkawtg's profile
nkawtg
272 posts in 1214 days
#8 posted 12-03-2015 07:16 PM
- Alexl
Ditto
View HokieKen's profile
HokieKen
4735 posts in 1102 days
#9 posted 12-03-2015 09:02 PM
It’s what your used to for sure. Can you move your fence rails/extension to set the saw up for using the fence on the left? On my saw, I could easily flip the rails so the fence extends to the left, maybe you can too? I’m not familiar with the Kobalt saws so I dunno.
-- Kenny, SW VA, Go Hokies!!!
View Daruc's profile
Daruc
460 posts in 1096 days
#10 posted 12-03-2015 09:11 PM
I’m ambidextrous, now I’m confused on where to put the fence.
View Gixxerjoe04's profile
Gixxerjoe04
850 posts in 1540 days
#11 posted 12-03-2015 09:18 PM
I’m not ambidextrous, but I do like half stuff left hand and the other half right handed. What really sucks is I turn left handed which is a real pain in the butt.
TheDane
#12 posted 12-03-2015 09:44 PM
Au-contraire, Gixxerjoe04 … you have no idea how many right-handed turners would like to be able to turn left-handed! I’m lucky … I can go both ways, a trait which I apparently inherited from my Dad.
ArtCam
#13 posted 12-03-2015 11:15 PM
I would give my right arm to be ambidextrous.
Daruc
#14 posted 12-03-2015 11:45 PM
Au-contraire, Gixxerjoe04 … you have no idea how many right-handed turners would like to be able to turn left-handed! I m lucky … I can go both ways, a trait which I apparently inherited from my Dad.
- TheDane
I don’t think you should blame your dad :>O
Now I’m really confused, if you stand on the other side of your lathe, wouldn’t it be the same as being left handed?
Try this! Switch hands and sign your name backwards, works (kinda)
View Jim Finn's profile
Jim Finn
2647 posts in 2885 days
#15 posted 12-03-2015 11:48 PM
I am right handed and I keep the fence to the left of the blade and reach over it with a push stick. I do not want to be in the
way of a kick back.
-- Website is https://craftingcouple.com/
