Motor size on homemade disc sander?
Forum topic by Ben Winchester posted 12-03-2015 11:22 AM 1708 views 0 times favorited 24 replies Add to Favorites Watch
View Ben Winchester's profile
Ben Winchester
22 posts in 892 days
12-03-2015 11:22 AM
Hey guys, I’d love to make a 12” disc sander, and I’m wondering if the motor I have laying around will be sufficient. It’s a 1/3 hp, but it spins at 15k rpm. It’s an old condenser fan motor. If I play with some pulleys to get the rpm down to a suitable level, will it have the torque I need?
-- Measure once, cut once, hope for the best.
24 replies so far
View dhazelton's profile
dhazelton
2755 posts in 2262 days
#1 posted 12-03-2015 12:50 PM
I have an old Sears combination belt/disc sander and the motor I put on was a 1/3 hp Dunlap and it works fine. You just need a light touch and don’t bear down too hard on it. 15K is crazy fast though. You may want to look for another motor.
MrUnix
6592 posts in 2164 days
#2 posted 12-03-2015 01:20 PM
A 15,000 rpm fan motor? Does it run on standard 120v AC or is it a DC motor?
(post a picture!!!)
View Gixxerjoe04's profile
Gixxerjoe04
850 posts in 1542 days
#3 posted 12-03-2015 01:28 PM
Do you have a lathe? I thought about making an attachment to make a 12” disc sander on it, haven’t got around to it yet though. 15k does sound really fast.
Ben Winchester
#4 posted 12-03-2015 01:58 PM
I dont have a lathe, but yeah 15000 is crazy fast, thats why i was thinking I could reduce it down with pulleys. I just wonder if it will be easy to stall it. I did some figuring and based on the formula T = Php 63025 / n i come up with a very small number.
And yes, its a standard 115v motor. I was surprised by the rpms too,but its for a condenser so maybe it has to turn fast to run a cooling unit
View Alexl's profile
Alexl
59 posts in 906 days
#5 posted 12-03-2015 02:44 PM
No way that is actually 15k loaded. a typical condenser fan is 18” in diameter (this is even on the smaller side). This diameter at 15k rpm produces a tip speed of 362 meters/second. The speed of sound is 340 m/s. I am pretty certain that nobody wants a condenser unit that produces sonic boom! (not to mention it would destroy itself)
beyond this, for 60hz AC, the maximum speed with 2 poles is 3,000 RPM.. and this is without any slip.
dhazelton
#6 posted 12-03-2015 11:13 PM
MrUnix
#7 posted 12-03-2015 11:21 PM
Yeah, it’s a brush type motor which is not the same as your typical induction motor and doesn’t follow the same rules :) You might be able to use one of those router speed controllers to slow it down as well, but I still don’t think it would make a good disc sander… those things don’t really have a lot of torque.
View bigblockyeti's profile
bigblockyeti
5093 posts in 1686 days
#8 posted 12-03-2015 11:28 PM
Given the resources and effort required, I’d be very tempted to find a 1hp induction motor that spins at the right rpm (1725) thus requiring no reduction, and has a shaft and bearings of appropriate size to mount a disc right to the motor. I see them all the time on CL for $50 or less.
bigblockyeti
#9 posted 12-03-2015 11:29 PM
The maximum speed for an induction motor with two poles at 60hz is 3600 rpm, the maximum speed for 50hz is 3000 rpm.
View JoeinGa's profile
JoeinGa
7735 posts in 1972 days
#10 posted 12-04-2015 12:19 AM
I started out trying a small motor, wasn’t worth a crap. Here’s what I ended up with …
http://lumberjocks.com/JoeinGa/blog/34349
View TheFridge's profile
TheFridge
9249 posts in 1451 days
#11 posted 12-04-2015 12:34 AM
I think a 5hp might be sufficient.
Ben Winchester
#12 posted 12-04-2015 12:59 AM
- TheFridge
Sweet I’ll grab one from work! SAND. EVERYTHING!!
I still don t think it would make a good disc sander… those things don t really have a lot of torque.
- MrUnix
Hurrah! Thats all I needed to hear! The magic “T” word! I’ll accept that this motor isnt appropriate for a disc sander. Do you think there is any shop application for thislittle guy?
View exelectrician's profile
exelectrician
2327 posts in 2393 days
#13 posted 12-04-2015 01:30 AM
I had a 12” sander once. the problem is that the speed of the disc at the outer edges almost always led to burning of the wood. Now I have a 8” sander everything works so much better. This is one more case where bigger is Not better.
-- Love thy neighbour as thyself
Alexl
#14 posted 12-04-2015 12:45 PM
Yeah, it s a brush type motor which is not the same as your typical induction motor and doesn t follow the same rules :) You might be able to use one of those router speed controllers to slow it down as well, but I still don t think it would make a good disc sander… those things don t really have a lot of torque.
- MrUnix
Ah, my mind was on induction motors, thanks for setting me straight. What the hell kind of fan is it supposed to be spinning though? When someone tells me condenser fan, i think HVAC or refrigeration. I have never seen a fan for one of these that would be small enough to spin at 15k
Alexl
#15 posted 12-04-2015 12:46 PM
- bigblockyeti
Doh! They say the better you get at higher level math, the worse you are at simple calculations. I am going to go with this excuse :)
