Which dado set to get
Forum topic by JMerr0928 posted 12-03-2015 01:04 AM 865 views 0 times favorited 11 replies Add to Favorites Watch
View JMerr0928's profile
JMerr0928
6 posts in 1257 days
12-03-2015 01:04 AM
Hello LJ,
I am in need of a new dado set and it seems like there is a lot of good options below 150 bucks. The Freud set is 90 bucks http://www.amazon.com/Freud-SD208-8-Inch-Professional-Dado/dp/B0000223O9/ref=sr_1_1?s=power-hand-tools&ie=UTF8&qid=1449104457&sr=1-1&keywords=dado+blade
The oshlun set is 95 http://www.amazon.com/Oshlun-SDS-0842-8-Inch-Tooth-Stack/dp/B0012YF25Q/ref=sr_1_3?s=power-hand-tools&ie=UTF8&qid=1449104457&sr=1-3&keywords=dado+blade
And the dewalt set is around 150.
Any recommendations? Any I am missing? It will be going in a 3 hp cabinet saw.
Thanks!
Jeff
11 replies so far
View Gerbah_from_Boston's profile
Gerbah_from_Boston
13 posts in 812 days
#1 posted 12-03-2015 02:20 AM
I have the Freud Super Dado stack. Great value for the money, has plywood thickness capacity and tells you if your clock is accurate to the thousands of a second. Ok, I admit, 2 out of the 3 things I said are true. I will say the cut is not as smooth as I would like and a router plane makes quick work of that though I understand that’s an issue with most if not all dado stacks…or perhaps at least if they are in my hands its an issue. It’s a quality set. Buy it.
View fuigb's profile
fuigb
466 posts in 2861 days
#2 posted 12-03-2015 02:54 AM
+1 to Gerbah: the Freud is a proven performer. I’ve done a ton with mine, and the noted shortcomings clean up very well with a chisel.
-- - Crud. Go tell your mother that I need a Band-aid.
View lateralus819's profile
lateralus819
2241 posts in 1793 days
#3 posted 12-03-2015 03:08 AM
I picked up the DeWalt a few weeks ago. I think it is a great piece of kit. Very nice case. Everything is clearly labeled.
Nice cuts too.
View realcowtown_eric's profile
realcowtown_eric
608 posts in 1841 days
#4 posted 12-03-2015 05:09 AM
I used to have a 10” dado set, and as it neared the end of it’s sharpenable life, I costed retoothing. A new 8” dado set would do everything I wanted, at 1/3 the cost.I have not been frustrated with the smaller diameter at all. I An 8” does everything I need .
Because I rabbet and dado a lot of melamine and hardwood ply, I went for the high tooth coun to minimize chip out., which costs a little more-carbide of course. The cost of the shopfox dado set in the box was 250ish, years ago but possibly cheaper now. I also use a lot of shop made zero clearance inserts for the same reason
And in the case I also have 4 cheapo 7 1/4” thin kerf skill saw blades to cut dado sbetween 3/32 and 1/4” and a set of plastic shims. Takes a licking and keeps on ticking.
Note…... most dado sets have a negative rake on the teeth, which will lift your work, so I often do a double pass over the blade just to clean it up and be precise
Eric
-- Real_cowtown_eric
View knotscott's profile (online now)
knotscott
7871 posts in 3279 days
#5 posted 12-03-2015 10:18 AM
The DW/Delta7670 is the cleanest cutting of the sets Ive used in the $120 range, plus it has a great carrying case and excellent shim stock. Once you get much north of that price range, the Infinity Dadonator is the best I’ve used regardless of price.
View Julian's profile
Julian
1267 posts in 2594 days
#6 posted 12-03-2015 05:41 PM
I have both the Freud and Oshlum dado sets. I would say they are both equal in performance and they do a very good job. I use them in a 3 hp table saw. I always use dado set with a zero clearance inserts.
-- Julian
View pintodeluxe's profile
pintodeluxe
5566 posts in 2717 days
#7 posted 12-03-2015 06:47 PM
Knotscott is the one to ask around here.
http://lumberjocks.com/reviews/634
I use the Freud Diablo, and it makes perfect dados and rabbets. Blind tenon shoulders are splinter-free. My only complaint is with through tenons, you need to cut very slowly, or it will occasionally chipout part of the tenon.
View John's profile
John
237 posts in 1485 days
#8 posted 12-03-2015 09:56 PM
+1 for Freud
-- I measured once, cut twice, and its still too short...
View rwe2156's profile
rwe2156
2796 posts in 1385 days
#9 posted 12-03-2015 11:04 PM
I think you’ve got your answer.
Now go git you one!!
View harriw's profile
harriw
128 posts in 2111 days
#10 posted 12-04-2015 12:03 AM
I have the 8” Oshlun, and have been quite happy with it. The dado bottoms are ever-so-close to perfectly flat (we’re talking a thousandth here… one pass with a scrap of sandpaper to smooth – I usually don’t bother as you can’t see the difference at all from the end of the board anyway). There is a bit of “bat ear,” but I think that’s kind of required to get nice clean edges (knotscott would know more).
I use mine in a contractor saw (ridgid TS3612), and have had no problems with it. My only beef was the cheap cardboard box it came in… so I promptly used my new dado stack to build a box-jointed box for it :)
I should also add that it’s the only dado stack I’ve ever used, so I can’t compare it to anything else. But as I said, I’m very happy with it.
-- Bill - Western NY
JMerr0928
#11 posted 12-04-2015 01:58 PM
Sounds good and thank you all for the responses. I will go pick up the Freud today!
Thanks!
