Enlon Fence question
Forum topic by Belg1960 posted 01-03-2010 10:57 PM 1481 views 0 times favorited 3 replies Add to Favorites Watch
View Belg1960's profile
Belg1960
1067 posts in 3060 days
01-03-2010 10:57 PM
Hi guys, I’m getting back into woodworking after laying off for a while and have now found that the wood side pieces of my Enlon cabinet table saw fence has developed a warp at the end due to moisture I’m pretty sure.
I want to replace them with pieces of phenolic resin and need help removing the wood as there is no mechanical fasteners that I can find. I assume this means that they are glued on, any help would be appreciated. Pat
-- ***Pat*** Rookie woodworker looking for an education!!!
3 replies so far
Belg1960
#1 posted 01-04-2010 05:03 AM
After finding out there were screws under the laminate I managed to get the wood and rest of the cheaply made fence boards off. Does anyone know where I can get some phenolic resin strips to attach to the fence and how to best accomplish attaching them? Thanks Pat
Belg1960
#2 posted 09-30-2011 12:19 PM
Guys, I’m bringing this back to the top for an additional question. I found some material thru Rockler and was wondering is there an adhesive which will hold this material to a plywood or solid substrate?
View mrg's profile
mrg
823 posts in 2994 days
#3 posted 09-30-2011 12:46 PM
Their is a company called Acme Plastic in NJ you can find them on the web. Give them a call and they can tell you what adhesive will work, I have done busines with them before and are very helpful.
-- mrg
