Mobile base for Powermatic 2800B Drill press.
Forum topic by bonesbr549 posted 12-02-2015 11:42 PM 1412 views 0 times favorited 8 replies Add to Favorites Watch
View bonesbr549's profile
bonesbr549
1469 posts in 2942 days
12-02-2015 11:42 PM
Any body out there own one and put a mobile base under it? I’ve got some nice 3” lockable casters and thought I’d build a nice wide bottom base and bolt it down. I called Powermatic and they only commented that be careful as its very top heavy.
I down loaded the manual and the base 13.5” x 20.5”. I’m struggling to see what would be a safe size to make the base for stability. I will bolt it down and my material will be sturdy but that height is concerning me a tad.
8 replies so far
View 716's profile
716
502 posts in 791 days
#1 posted 12-03-2015 12:22 AM
Manual for Grizzly mobile base says that in case of narrow items you should not cut the base rails to make it smaller but keep it extended.
They suggest to make a 1 1/2” plywood plate, set it into the mobile base and fasten the equipment to the plate.
-- It's nice!
View conifur's profile
conifur
955 posts in 1026 days
#2 posted 12-03-2015 12:24 AM
I think Woods Mag has one and it was on a Powermatic.
conifur
#3 posted 12-03-2015 12:28 AM
View SawSucker's profile
SawSucker
110 posts in 803 days
#4 posted 12-03-2015 12:35 AM
I tried it once and won’t do it again. Too dangerous.
bonesbr549
#5 posted 12-03-2015 12:42 AM
Thanks all and for the links. That design gets it much closer to the ground.
View Jerry's profile
Jerry
2517 posts in 1523 days
#6 posted 12-03-2015 01:06 AM
I’ve used these with great success. I have one under my Grizzly table saw
http://www.grizzly.com/products/Super-Heavy-Duty-Mobile-Base/D2058A
-- There are good ships and there are wood ships, the ships that sail the sea, but the best ships are friendships and may they always be. http://www.geraldlhunsucker.com/
View Gerbah_from_Boston's profile
Gerbah_from_Boston
13 posts in 783 days
#7 posted 12-03-2015 02:48 AM
If you are to go with casters, you want the ones that lift completely off the ground, dropping the base to the floor. The drill press will tend to wobble slightly on casters. If you plan to clamp every project to the table it’s probably ok. Me, I’m far too lazy for that bullsh*t.
Try this mobile base and add a plywood bottom:
http://www.rockler.com/power-tool-mobile-base-hardware
Or better yet, buy this and mount it to said piece of plywood base
http://www.rockler.com/caster-only-for-mobile-base
woodbutcherbynight
3760 posts in 2284 days
#8 posted 12-04-2015 04:01 AM
Some good ideas here, thanks for the posts.
