Heating the shop for winter question
Forum topic by UpstateNYdude posted 12-02-2015 03:34 PM 1421 views 0 times favorited 42 replies Add to Favorites Watch
View UpstateNYdude's profile
UpstateNYdude
916 posts in 1981 days
12-02-2015 03:34 PM
So I have fairly large garage 24×32 and its walls are insulated not the ceiling yet as I haven’t had the time. I’m looking at purchasing a heater temporarily until next year when I get my NG Modine Hot Dawg heater installed. I’m looking at the Mr. Heater 30,000 BTU Propane Vent Free heater and wondering if this will suffice I have two 20lbs tanks and I usually only get 2-3 hours at night on the weekdays and 5-6 on the weekends.
Is this a good heater that won’t eat through a 20lb tank in a week? Do these off gas any moisture to the air that will rust my cast iron surfaces?
This is what I’m looking at
http://www.ruralking.com/mr-heater-30-000-btu-propane-blue-flame-vent-free-heater
-- Nick, “I am always doing what I cannot do yet, in order to learn how to do it.” – Vincent Van Gogh
42 replies so far
UpstateNYdude
#1 posted 12-02-2015 03:37 PM
Confusing it reads like you need a 100lb tank, but then has acceptance for 20lb weird.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2367 days
#2 posted 12-02-2015 03:47 PM
According to the Q&A on the link you posted, the admin states that the tank will use 1.38lbs/hr on a medium setting. So, around 14 hours per 20# cylinder on medium. Sounds like with your usage, you’ll eat through that tank in a week, assuming you start it up a bit before you begin working, and maybe shut it off a bit before you’re done. They also say in the Q&A not to use anything less than 100lb, but not sure why that is.
4986 posts in 2491 days
#3 posted 12-02-2015 03:53 PM
I had one in my last garage. It was 26×22, insulated walls and ceiling, but no vapor barrier anywhere. I install;ed the heater and ran it one day. I happened to go up into the attic the next day only to see water dripping from the deck of the roof. They give off a lot of moisture, I disconnected mine that day, removed it and gave tit to a Goodwill store. As for the 20# tank, remember that’s less than 5 gallons. So, 95K BTU per gallon, each gallon will allow the heater to burn about 3 hours…or 15 hours of burn time roughly. It won’t be running all the time (I wouldn’t think), but that might give you some idea. If it were me, I think I would look into some small electric heaters but that’s juts my approach.
View summerfi's profile
summerfi
3925 posts in 1685 days
#4 posted 12-02-2015 03:59 PM
My shop is exactly the same size as yours, but the ceiling is insulated. I use a 45K BTU vented natural gas heater and it works fine. I think the 30K would be a little on the small side, and I would definitely be concerned about the moisture a non-vented heater would put in a shop full of metal tools. If it’s only temporary, you might get by with it. I supplement my heat with this, and on sunny days I never have to turn my gas heater on, no matter how cold it is. It works amazingly well.
-- Bob, Missoula, MT -- Rocky Mountain Saw Works http://www.rmsaws.com/p/about-us.html
UpstateNYdude
#5 posted 12-02-2015 04:14 PM
Would the type of heater matter for the moisture, does the convection produce more then the infrared model? Is one worse than the other for a woodshop?
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1174 days
#6 posted 12-02-2015 04:38 PM
This type of heater (non-vented) will dump the fumes back into the room. Including the Carbon Monoxide. This is not safe to breath!
I would suggest that you bite the bullet and buy the permanent heater now instead of risking your health for a year.
#7 posted 12-02-2015 04:53 PM
- UpstateNYdude
Not in my experience, they both put out enough to be a problem.
View johnstoneb's profile
johnstoneb
2914 posts in 2171 days
#8 posted 12-02-2015 05:01 PM
One of the byproducts of combustion is water. You need an externally vented heater to keep from breathing the combustion gases (one of which is carbon monoxide) and water vapor/
-- Bruce, Boise, ID
UpstateNYdude
#9 posted 12-02-2015 05:14 PM
Well unfortunately I don’t have the time and daylight to dig trench for a gas line running to my garage and bore through my foundation to get it there. So that is not a possibility until spring, I need something that can heat the space that doesn’t require gas to install and isn’t over $300 if possible.
View jkinoh's profile
jkinoh
95 posts in 1895 days
#10 posted 12-02-2015 05:23 PM
I’d make the time to insulate ceiling first, then figure what heat source you want.
-- Why buy it for $300 when you can make it for $500!!
UpstateNYdude
#11 posted 12-02-2015 05:34 PM
This is a TEMPORARY solution, I know I need to insulate I’m not installing it until I finish the wiring for the new heater which I can’t dig trench for until spring.
All I need are heaters that will make it warm enough so I can feel my face after 20 minutes when it gets cold outside for the next 5-6 months (YAY NE NY winters last forever), that won’t rust my tools, cause a fire or kill me lol.
View bondogaposis's profile
bondogaposis
4727 posts in 2349 days
#12 posted 12-02-2015 05:39 PM
Here is a link to a BTU calculator that you can use to figure what size heater you need. But first insulate your ceiling or you’ll be just wasting your money.
-- Bondo Gaposis
View Woodknack's profile
Woodknack
11626 posts in 2378 days
#13 posted 12-02-2015 05:46 PM
For temporary I would just get an IR heater.
View TinWhiskers's profile
TinWhiskers
179 posts in 950 days
#14 posted 12-02-2015 05:56 PM
This is a TEMPORARY solution, I know I need to insulate I m not installing it until I finish the wiring for the new heater which I can t dig trench for until spring.
- UpstateNYdude
You have power in your garage? Why a trench? My 35k BTU Hot Dawg is on a 20 A circuit. If I had to I could run it off an outlet. 24×36 shop.
Really beware of old borrowed heaters. I borrowed a heater once, must have been 50K. Really put out the heat. Went to use a handheld propane torch and it wouldn’t light. Happened to have another on the bench. That wouldn’t light either. OUT went the borrowed heater. I have a carbon monoxide detector in my shop too.
If you want to go from outside temp to 50 it would take forever with a 30K BTU. How about 50K?
UpstateNYdude
#15 posted 12-02-2015 05:59 PM
What about something like this I already have the plug required or is this dangerous for fine dust and the like catching fire?
showing 1 through 15 of 42 replies
