Bandsaw Fence??
Forum topic by GuyK posted 01-03-2010 03:04 PM 1652 views 0 times favorited 12 replies Add to Favorites Watch
View GuyK's profile
GuyK
356 posts in 3985 days
01-03-2010 03:04 PM
Topic tags/keywords: fence bandsaw
I am in need of a fence on my bandsaw. I am looking for your thoughts on this. What do you use and what would you recomend?? TIA.
-- Guy Kroll www.thelandsathillsidefarms.org
12 replies so far
View hairy's profile
hairy
2607 posts in 3438 days
#1 posted 01-03-2010 06:13 PM
I like this Kreg unit. It is simple , sturdy and accurate.
http://www.woodcraft.com/Product/2005244/22627/Kreg-Bandsaw-Fence.aspx
I got mine off craigslist kinda cheap. Before that I clamped a board where I needed it.
-- My reality check bounced...
View miles125's profile
miles125
2180 posts in 3911 days
#2 posted 01-03-2010 06:22 PM
Make one out of wood and secure it with c clamps.
-- "The way to make a small fortune in woodworking- start with a large one"
View GaryK's profile
GaryK
10262 posts in 3894 days
#3 posted 01-03-2010 06:28 PM
Both the above will work.
I have the Kreg fence and it’s just OK.
View 8iowa's profile
8iowa
1569 posts in 3667 days
#4 posted 01-03-2010 06:31 PM
Make sure that the fence can be adjusted to offset angles in order to compensate for the blade’s drift (leade).
This is absolutely necessary for successful resawing.
View Jimi_C's profile
Jimi_C
507 posts in 3141 days
#5 posted 01-03-2010 06:45 PM
I was looking at the Carter magfence, since the bandsaw I got recently is a 1940’s model and I’d have to drill holes for the Kreg (which I was looking at before). In addition to the drilling issue, the groove in the table of the bandsaw comes out the same edge that the fence would attach to. I asked Kreg if they had considered that issue (since newer models seem to have the groove coming out the side perpendicular to the blade), and they said either I’d have to take the fence off every time I changed blades, or I’d have to cut the fence in half (meaning more hole drilling, in both the table AND Kreg fence).
On top of that, the magnetic fence is a bit cheaper, and I believe the slots in it would work with the Kreg resaw attachment – but I have not confirmed that. I need new tires and blades for mine, so the fence will be down the road a while (gonna be using the wood and c-clamp method for a while I think).
-- The difference between being defeated and admitting defeat is what makes all the difference in the world - Upton Sinclair, "The Jungle"
View John's profile
John
190 posts in 3489 days
#6 posted 01-03-2010 10:55 PM
I think you will make out just fine with a tall home made fence clamped to the table. I do have a Rikon fence that came tithe the saw that works fine but I would like a taller fence.
-- John, Long Island, NY
View daltxguy's profile
daltxguy
1373 posts in 3820 days
#7 posted 01-03-2010 11:08 PM
I use a hardwood board clamped to the table. Does everything I want. It’s cheap, it’s renewable. Everything else is just an imitation!
-- If you can't joint it, bead it!
View BlankMan's profile
BlankMan
1490 posts in 3259 days
#8 posted 01-03-2010 11:57 PM
I bought the Delta one when I first got my bandsaw, that was about my only choice at the time, work’s just fine. Now if I were to do it I’d consider the Kreg but it might come down to cost, IMO I don’t need a lot of whistles and bells and ultra high accuracy, bandsaw blades drift so just a fence will do. :)
-- -Curt, Milwaukee, WI
View Pete_Jud's profile
Pete_Jud
424 posts in 3659 days
#9 posted 01-04-2010 12:54 AM
I use two pieces of hardwood glued and screwed at a right angle and clamps. Works great.
-- Life is to short to own an ugly boat.
View willy3486's profile
willy3486
77 posts in 3303 days
#10 posted 01-04-2010 02:23 AM
Someone tossed a old tablesaw out and I got it. It was one of those cheaper units that had the blade mounted to the motor. But it had a good fence setup. I just took the fence off and rails to use on the saw. The fence was made out of aluminium and I just cut it down to where it would fit. Works good so far and was a freebee.
View bigike's profile
bigike
4053 posts in 3194 days
#11 posted 01-04-2010 02:29 AM
u should get a driftmaster from laguna, that’s one sweeet fence. im getting a rikon 14” bandsaw and if i can fit a driftmaster i am. well good luck with which ever way u go. but check it out?
View Eric_S's profile
Eric_S
1565 posts in 3101 days
#12 posted 01-04-2010 02:47 AM
The new issue of fine woodworking goes over making a really nice fence for the bandsaw.
-- - Eric Noblesville, IN
