Taking the wobble out of the grinding wheel?
Forum topic by DocSavage45 posted 12-02-2015 01:40 AM 1232 views 0 times favorited 14 replies Add to Favorites Watch
View DocSavage45's profile
DocSavage45
8430 posts in 2716 days
12-02-2015 01:40 AM
Topic tags/keywords: resource tip question 8 grinder sharpening
Hey Lj’s!
Went to do a quick sharpening of my carpenter Stanley work chisels. Pulled out my 8 inch Porter Cable variable speed grinder.
I had purchased a Norton white wheel for finer grinds and I have one that came with the grinder. Set it on a very smooth surface and it started dancing with vibration. Put a pad under it and started it up.
I had read that you can shim the stones to get them in balance. The white Norton stone as I measured the run out was 1/16th plus out of true
I know there is wisdom here and experience that can help me correct this issue.
What is the best and safest way to reduce the wobble in the stone? I read somewhere that I “should not attempt to flatten the sides of the wheel.”
Your suggestions are appreciated.
-- Cau Haus Designs, Thomas J. Tieffenbacher
14 replies so far
View giser3546's profile
giser3546
179 posts in 1346 days
#1 posted 12-02-2015 01:43 AM
What rpm are you running it?
-- "If you wait for it to rain, It will"
DocSavage45
#2 posted 12-02-2015 01:49 AM
I’ve run it to around the middle range with the least amount of vibration. Don’t know exact rpm.
View mrg's profile
mrg
791 posts in 2873 days
#3 posted 12-02-2015 02:26 AM
Dress the wheel. Rotate the wheel to help balance it. Also if you have a lathe turn yourself a bushing or see if you hardware store has a solid bushing for the wheel. You can also order a solid aluminum one from wood turners catalog.
-- mrg
DocSavage45
#4 posted 12-02-2015 02:45 AM
Thanks!
Dress only the face? The wobble seems only in a quarter of the wheel? I’ll have to check, and I’ve read that the stone can be fractured by replacing the bushing with something harder?
I have a lathe but I need the grinder to sharpen my new gouges? LOL!
View RobS888's profile
RobS888
2335 posts in 1718 days
#5 posted 12-02-2015 03:41 AM
Put an index mark on the shaft, then 8 equidistant marks around the wheel on the label (past the edge of the large washer) then test rotate, test,...
Oh, I also sanded the washer so it was flat where it met the wheel to get more contact.
I was pleased at how well this worked.
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
View waho6o9's profile (online now)
waho6o9
8070 posts in 2450 days
#6 posted 12-02-2015 04:07 AM
https://www.youtube.com/watch?v=_7OoqJN2L4Y
HTH
I did turn a walnut bushing and it was a vast improvement over the plastic
supplied one.
DocSavage45
#7 posted 12-02-2015 04:40 AM
RobS888, waho609,
Thanks! This will get me on track or rebalanced??
View Bricofleur's profile
Bricofleur
1440 posts in 3066 days
#8 posted 12-02-2015 12:35 PM
Tom, you may want to put your hand in your pocket and get one of these (link below). A while ago I saw a video and it should do the job. And it will last for ever on the same grinding wheel.
http://www.leevalley.com/US/wood/page.aspx?p=49226&cat=1,43072
You can watch a review presented here on LJ in 2012
http://lumberjocks.com/reviews/3053
Best,
Serge
http://atelierdubricoleur.wordpress.com
-- Learn from yesterday, work today and enjoy success tomorrow. -- http://atelierdubricoleur.wordpress.com
DocSavage45
#9 posted 12-02-2015 04:50 PM
Serge,
Ill keep it in mind.
Thanks for the suggestion.
waho6o9
#10 posted 12-02-2015 04:55 PM
RobS888, waho609,
From my experience it will get you on track not sure on the balancing part though.
DocSavage45
#11 posted 12-02-2015 05:00 PM
wahoo609,
LOL!
Bricofleur
#12 posted 12-07-2015 04:16 PM
Tom, you got to Watch this video about setting a grinder. You’ll get all the answers you’re looking after.
https://www.youtube.com/watch?v=MakQfF5yIyo&feature=player_embedded&list=PLOUEnRdBNW4P1Hxe_Xg1gC2Kt6Oeklg1m#t=153
Just be patient !! :)
Best,
Serge
DocSavage45
#13 posted 12-07-2015 06:18 PM
Serge,
THANK YOU!
Watched Tim Yoder set up the grinder. Need to shim both sides of wheel. Didn’t see that in my searches , just said shim. Some suggest turning your own sleeve, but I’ve not started turning as I wanted to make sure I had an edge that would cut on the tools I have.
Saw a steel sleeve on amazon which I’m going to purchase. Not expensive.
I want to get started before I think about spending more money.
Thanks for thinking about me!
Tom
Bricofleur
#14 posted 12-07-2015 10:09 PM
Tom, you don’t want to let a friend down !
I’m glad you like it.
Best,
Serge
