Stupid stupid me. China 3/4" plywood is thinner than TRUE 3/4" plywood!
Forum topic by Holbs posted 12-02-2015 01:32 AM 1551 views 0 times favorited 16 replies Add to Favorites Watch
View Holbs's profile
Holbs
2032 posts in 2267 days
12-02-2015 01:32 AM
Topic tags/keywords: plywood 34 18 mil 0703 china plywood
I remember years ago, I read that box store 3/4” plywood was not actually 3/4” or 0.750”, but more 45/64th or 18mil 0.703”. I use SketchUp to create things just to see what the end result kinda looks like. For some mystical old man reason, I’ve been inputting 3/4” and not 45/64th and noticed some joints being loose or actually off, because I forgot there was a measurement difference. Arrggggh. I talked to my hardwood supplier and asked about his 3/4”. He said it is exactly that…3/4”, and it’s only $2 less than the box stores. So keep that in mind for those who buy plywood at the box stores vs hardwood supplier.
I am not sure what everyone else pays for red oak plywood, but here in northern NV it is a little more spendier than average since located in wasteland. $48 for 0.750” is better than paying $49 for 0.703”. Hardwood supplier says plywood gets cheaper as well, just right now it’s $48.
  • On a side note, my hardwood supplier is only open Mon-Fri 8am-5pm, closed weekends. I do not have time thru the week to get the 3/4” plywood due to daytime job of 8am-4:30pm (hence, relying on box stores often). I asked him about it and he said order it via phone during the day. They will set the order outside (no security, possible theft if sits outside too long) and I can rush home to grab my Dodge 1500 pickup and be there by 5:15pm’ish to grab it. Ok..maybe 5:30pm with rush hour traffic.
16 replies so far
View ChefHDAN's profile
ChefHDAN
1230 posts in 3087 days
#1 posted 12-02-2015 01:51 AM
Question or rant, I’m not sure, but I feel your pain (with my best Clinton accent)
I’ll pile on because I have 2 sets of “undersized” plywood bits that are a crap shoot to have fit the ply. Best lesson learned on my side is an exact width dado jig when applicable, shims on the dado, tape shims on the router guide fence for 2nd pass, AND ALWAYS remember to cut a Damn sample first… Don’t know why I frequently forget the small sample before the 3 foot dado…
Holbs
#2 posted 12-02-2015 01:54 AM
there..added ”!” :)
My hardwood supplier said his 3/4” plywood is exactly 3/4”. I have not bought any as yet. Would this be true for most hardwood suppliers? Or is quality plywood still off a little here and there?
View Daruc's profile
Daruc
460 posts in 1370 days
#3 posted 12-02-2015 02:40 AM
I don’t think your going to get a full .750 in a plywood these days. China or American
(could be wrong though)
woodbutcherbynight
5825 posts in 2646 days
#4 posted 12-02-2015 03:32 AM
Kinda like a 2×4 has not been a 2×4 for how long? Anyone?
View rwe2156's profile
rwe2156
3230 posts in 1718 days
#5 posted 12-02-2015 01:02 PM
I agree with Wood dust. The premium ply I’ve bought from my supplier is 18 or 19mm, not 3/4”.
Don’t think they make it anymore.
In the end, it doesn’t matter you just build it into the design.
I’ve found it helps tremendously to simply convert everything to metric.
View bondogaposis's profile
bondogaposis
5151 posts in 2589 days
#6 posted 12-02-2015 01:32 PM
I haven’t seen any true to dimension plywood for many years, even the $120 a sheet stuff.
-- Bondo Gaposis
View johnstoneb's profile
johnstoneb
3072 posts in 2410 days
#7 posted 12-02-2015 01:51 PM
I think all plywood is metric. Even that made in the US because it is sold on an international basis and the rest of the world is metric.
I use Sketchup for my plans but in the shop once the outside dimensions are established everything is measured and cut to fit.
-- Bruce, Boise, ID
5236 posts in 2731 days
#8 posted 12-02-2015 01:53 PM
The only plywood I use for furniture projects anymore is cabinet grade ply from Columbia Forest Products. Even at that, none of it except the prefinished both sides is a true 3/4” thick (or 1/2”, or whatever). I guess the prefinished is because of the thickness of the coating…
View Nubsnstubs's profile
Nubsnstubs
1434 posts in 1967 days
#9 posted 12-02-2015 02:52 PM
I owned my own cabinet shop for 40+ years, and from day one, I have never seen a 3/4” sheet of furniture grade plywood measure out to 3/4”. Always about 1/32” smaller. Doesn’t matter the grade, A1, A2, or B grades to Shop grades. Always the same.
When they started using MDF as the core, the 3/4” sheets measure approximately .740”. I’ve noticed that 1/4” MDF core sheet is as close to 1/4” as you can get. ............... Jerry (in Tucson)
View bonesbr549's profile
bonesbr549
1579 posts in 3305 days
#10 posted 12-02-2015 02:56 PM
Yep, never been 3/4 in my world. I even bought a plywood router bit that was undersized on purpose, but that even stopped working as they thin the veneers to squeeze out another few cents out of every sheet. Someone finally showed me a method of cutting grove to a standard width and cutting a slight rabbit(rebate whatever) on the edge of the ply and its never been a problem since. Fits snug and gives a bit of extra rigidity.
View helluvawreck's profile
helluvawreck
32086 posts in 3104 days
#11 posted 12-02-2015 03:09 PM
I’m not sure when was the last time I had ‘3/4 plywood’ that was 3/4”, but it’s been quite a long while ago if ever. I always fit the dados to the actual thickness of the plywood either by using shims on dado sets and/or undersized router bits.
helluvawreck aka Charles
View CaptainSkully's profile
CaptainSkully
1607 posts in 3796 days
#12 posted 12-06-2015 04:39 PM
They sell 23/32” router bits to make 3/4” plywood fit perfectly. This comes in super handy for letting shelves into the sides of cabinets. There’s also a way to build a dado jig so that you adjust it up against your stock, regardless of the thickness and the jig allows you to make a dado that fits perfectly.
-- You can't control the wind, but you can trim your sails
View Ger21's profile
Ger21
1075 posts in 3368 days
#13 posted 12-06-2015 04:44 PM
Hardwood plywood is almost never 3/4”. It’s almost always thinner, and can and will vary in thickness form batch to batch.
We’ve done jobs where we’ve ordered 150 sheets, and ended up with 3 different thicknesses.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View Richard H's profile
Richard H
489 posts in 1918 days
#14 posted 12-06-2015 06:31 PM
I also find it odd that you hardwood dealer said it was exactly 3/4” since I have not seen that in a long time either. Is the plywood they are selling a traditional veneer core or is it something like a MDF core?
It seems like you are going though a lot of trouble to make the measurements match your plan exactly. I don’t know how elaborate these projects are but does your cut list really need to be that exact? I know it’s how each person approaches this issue but I rarely use plan dimensions for more than a reference and fit to size most of my pieces. I suppose if I was making a bunch of the same thing and wanted to batch them out or if I was using a CNC machine exact would be more important but for a one off project it just seems like a lot of trouble for little gain to me.
Holbs
#15 posted 12-06-2015 07:03 PM
Rich…
I have not made a return trip to this hardwood dealer, but when I do I will bring dial calipers :) From the replies here, I doubt to see true 3/4” sheet goods.
I really HATE seeing a sliver gap in any of my joints, even if it’s 1/16th”. It’s not critical but it does get under my skin. When I see the fine precision wood working projects, I see perfectly mated joints, no gaps, etc. I am making work shop organization projects this winter, so thought it best to keep the practice of precision. Example: if I cut a 4 ‘x 4’ square, I do not want a 4’ x 3’ 11 7/8” square. I’ve gotten really good lately :) With my Grizzly track saw, I am down to 1/32nd deviation.
But you are right, Richard about plans being used only as reference. I am just not 100% comfortable keeping track of the different measurements and picturing how it goes together in my head like lego’s. This, I assume, comes with experience. I have much more to go :)
