Outdoor Finishing Question
Forum topic by CanadianWoodChuck posted 1234 days ago 1099 views 1 time favorited 10 replies Add to Favorites Watch
CanadianWoodChuck
360 posts in 2081 days
1234 days ago
Topic tags/keywords: finishing outdoor meranti resource question
Hi felow LJ’s. I just finished two folding Adirondack chairs using Meranti. Meranti is a Malaysian Hardwood used a lot for window and door frames and is suppose to stand up really well outside. My problem is I don’t know how to finish it. Anything I’ve tried on outdoor projects has never stayed on very long and exterior varnish is just a waste of time. I was thinking about just putting a coat of boiled linseed oil, whch really makes the colour pop. Has anyone ever tried BLO on an outdoor project? How did it work out for you. Or, of course any other finishes that you have had good luck with. Thanks Bruce
10 replies so far
View bobasaurus's profile
bobasaurus
685 posts in 1352 days
#1 posted 1234 days ago
I would try Minwax Helmsman spar urethane. It’s supposedly UV resistant and can expand with temperature/humidity changes without cracking. I’ve never actually used it for an outdoor piece, though.
Todd A. Clippinger
8654 posts in 2267 days
#2 posted 1234 days ago
About the best finish for outdoors is Sikkens and it is really expensive. Last time I used it I think it was $75 per gallon and it is only sold through distributors.
Any type of oil that is rated for exterior use will protect the wood but still allow it to turn silver over time. There are no U.V. inhibitors like in the Sikkens product.
Many of the guys I know use Messmers instead of Sikkens and it is more widely available at the chain hardware stores.
Todd A. Clippinger
#3 posted 1234 days ago
One other thing to keep in mind when it comes to outdoor finishes is this, regular maintenance is much easier and less costly than letting the finish deteriorate to the point of needing stripped.
The surface coat is sacrificial. It should get a light sanding and a new coat applied every couple of years or as necessary depending on the project’s needs.
CanadianWoodChuck
#4 posted 1233 days ago
Thanks for your input, Sikens I’m quite familiar with, my home is board and batten and it took 17 gallons to complete. :)
View Ger21's profile
Ger21
594 posts in 1299 days
#5 posted 1233 days ago
Sometime in the last year, FWW had an article on exterior finishes. The best is several coats of thinned epoxy, followed by a UV inhibiting varnish or polyurethane.
http://www.finewoodworking.com//item/13849/the-ultimate-outdoor-finish
-- Gerry, http://home.comcast.net/~cncwoodworker/CNC_Woodworker.html
Todd A. Clippinger
#6 posted 1233 days ago
Gerry – I missed that one, I will have to check it out.
I admit that I gravitate towards canned products due to my background as a remodeling contractor.
View stefang's profile
stefang
9448 posts in 1502 days
#7 posted 1233 days ago
I remember that test in FWW and the conclusion was that a marine varnish was best and that epoxy with poly which had uv inhibitors wasn’t any better than the poly alone. Sorry Gerry, I’m not trying to be ornery, but if you reread that article you will see I’m right.
-- Mike, American in Norway
View thewoodmaster's profile
thewoodmaster
53 posts in 1360 days
#8 posted 1233 days ago
Outdoor Oil made by general finishes. used it on my adirondack chairs and it is holding up nicely.
-- dan "insert pithy woodworking coment here"
CanadianWoodChuck
#9 posted 1233 days ago
Thanks everyone – I’ll check the article out
Woodmaster I love your avtar, the outdoor oil sounds interesting, now to find General finishes in Canada :)
Ger21
#10 posted 1233 days ago
I re-read the article (at least the last paragraph), and the conclusion was that the 7 coats of Epifane varnish was equal to 3 coats of epoxy + 5 coats of Epifane. Both were better than poly alone.
