Miter Saw Kickback - now blades wobble some
Forum topic by Keith Kelly posted 12-01-2015 06:51 PM 2028 views 0 times favorited 11 replies Add to Favorites Watch
View Keith Kelly's profile
Keith Kelly
263 posts in 1688 days
12-01-2015 06:51 PM
Last weekend, I had a kickback sort of thing with my miter saw. I believe what happened was that I was holding a piece that had recently been glued along a weak area, but not fully set. My theory is that the joint failed with my pressure against the fence, and then there was a loose object that the blade caught. It made quite a loud bang/whack/wham (batman style) and sent wood flying and broken.
But the point of this thread is: my miter saw has a wobble now. I figured it was the blade (100t Diablo), so I swapped to a different blade, and the wobble still exists. It’s minor, but definitely visible by eye.
So I’m trying to figure out where to go from here. Just use it and take slow cuts? Replace some part of the arbor, etc.
What would you check next?
-- Keith - Bolivar, Missouri, http://www.SquareOneWoodworks.com
11 replies so far
View distrbd's profile
distrbd
2252 posts in 2471 days
#1 posted 12-01-2015 06:57 PM
I definitely will not use it with a wobble,your best bet is to buy a good used saw unless the miter saw is a good one like Dewalt or Bosch ,Milwaukee ,then see if you can replace the the bearing or the complete motor but I doubt it would be cost effective.
-- Ken from Ontario, Canada
Keith Kelly
#2 posted 12-01-2015 07:00 PM
Yikes.
It’s a Ridgid 12” and I’d consider it a decent saw. Come on, how about news I’d rather hear? :)
Is it typical for kickback to cause something to bend/break other than the blade?
View mahdee's profile
mahdee
3888 posts in 1792 days
#3 posted 12-01-2015 07:05 PM
I think Ken is right. Take the blade out and turn it on. If the shaft is wobbling, then either it is bent or the bearing has come lose or something. You would have to take the motor out and possibly replace the armature or bearing and in the worst case scenario, both.
-- earthartandfoods.com
MrUnix
6766 posts in 2223 days
#4 posted 12-01-2015 07:10 PM
Unfortunately, it sounds like you may have bent the arbor – which is actually the end of the motor armature. I’d throw a dial indicator on it and see if you can pinpoint where the wobble is coming from first though..
View TheFridge's profile
TheFridge
9607 posts in 1510 days
#5 posted 12-01-2015 07:16 PM
Unfortunately, it sounds like you may have bent the arbor – which is actually the end of the motor armature. I d throw a dial indicator on it and see if you can pinpoint where the wobble is coming from first though..
- MrUnix
Ditto
View waho6o9's profile
waho6o9
8207 posts in 2601 days
#6 posted 12-01-2015 07:23 PM
On your next saw maybe make a zero clearance insert.
View pottz's profile
pottz
2634 posts in 1008 days
#7 posted 12-01-2015 07:24 PM
i agree with the others if you bent the shaft go see santa at the mall sorry but it probably would not be worth the cost to repair.
View splintergroup's profile
splintergroup
2073 posts in 1246 days
#8 posted 12-01-2015 08:10 PM
Some saws have the motor offset from the arbor to increase cut capacity. If this is the case, the arbor might be separate from the motor shaft and be a lot cheaper as a replacement part.
splintergroup
#9 posted 12-01-2015 08:14 PM
I had a look-see at a generic Rigid 12” CMS and the arbor is separate ($10). See if you model is that way.
(Of course determine that it is a bent arbor first 8^)
View crank49's profile
crank49
4032 posts in 2995 days
#10 posted 12-01-2015 08:34 PM
Either the arbor shaft is bent or the bearing housing is busted. A bent shaft can probably be replaced. Busted housing = shopping trip.
View Holbs's profile
Holbs
1878 posts in 2053 days
#11 posted 12-02-2015 01:05 AM
zero clearance insert for a miter saw. who knew! I like it…
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
