Stabilizer or not ?
Forum topic by 716 posted 12-01-2015 06:48 PM 706 views 0 times favorited 15 replies Add to Favorites Watch
View 716's profile
716
502 posts in 914 days
12-01-2015 06:48 PM
Is the benefits of a stabilizer overweight its negatives on a thin kerf blade ?
I see the following complains about them:
1. When used in pairs the stabilizer moves the blade left for the thickness of one sabilizer so everything on the table saw needs to be retuned. This includes the riving knife, fence, throat inserts….
2. When a single stabilizer is used it warps the blade as the permanent flange on the other side of the blade is smaller in diameter.
Then there are issues such as a possibility to touch zero clearance insert when raising the blade, but they seems to be easier to address.
-- It's nice!
15 replies so far
View SirIrb's profile
SirIrb
1239 posts in 1228 days
#1 posted 12-01-2015 06:52 PM
Use a thick kerf blade.
View 716's profile
716
#2 posted 12-01-2015 07:23 PM
- SirIrb
If let’s say you cut a 10” board into 1/4 stripes you can make 29 stripes with a thin kerf blade and only 26 with a standard kerf.
But you do make 30% more saw dust with a thick kerf blade if that is your goal.
-- It's nice!
View bonesbr549's profile
bonesbr549
1548 posts in 3064 days
#3 posted 12-01-2015 07:29 PM
I used thin kerf blades in a previous life. I had the stabilizer on my RAS and it helped with the whine. It cuts down on cut depth which I did not like on my TS. In the end think it was a marketing thing. I got ti to save on lumber (exotics). Truth be told the savings is minimal and when you get into thicker stock like 12 & 16 quarter, I did not like the deflection. I sold my forrest WWI & WWII and stablizer and moved to regular kerf blades and never looked back.
Unless you have an underpowered saw there is no need.
Thats my opinion but that and a buck fifty will get you a cup of coffee.
View knotscott's profile
knotscott
8012 posts in 3373 days
#4 posted 12-01-2015 07:32 PM
I good quality thin kerf blade that’s mounted on a saw with low arbor runout that’s cutting flat straight wood generally shouldn’t need a stabilizer. If you have a saw with excessive runout or a blade that’s not quite true, a stabilizer can help, but it doesn’t really solve the root problem. I’ve never noticed a difference with them or without, so I vote not to bother with them. They don’t really hurt anything but your wallet, and they limit cutting height capacity.
A 1/8” full kerf blade does indeed produce more dust than a thin kerf blade….whether or not that’s significant depends on you.
4985 posts in 2490 days
#5 posted 12-01-2015 07:33 PM
I’ve not seen any benefits from using a pair of stabilizers. The cut didn’t seem to be more smooth, and they might reduce the depth of cut. The few TK blades I had were the higher quality blades, maybe they help with some of the cheaper ones; but I found no reason to use the stabilizers, and several reasons not to use them. It’s been some time since I used them, and I’ve switched mostly to full kerf blades at this point.
View MrUnix's profile
MrUnix
6709 posts in 2196 days
#6 posted 12-01-2015 07:38 PM
If let s say you cut a 10” board into 1/4 stripes you can make 29 stripes with a thin kerf blade and only 26 with a standard kerf.
For cutting 1/4” strips in a 10” wide board, I’d head for the bandsaw. Trying to do really thin stuff on the table saw isn’t exactly something I like doing :)
View MrRon's profile
MrRon
4764 posts in 3241 days
#7 posted 12-01-2015 08:23 PM
It really comes down to the type of woodworking you do. If you are cutting hard woods, thick woods, construction quality woods, a full kerf blade would be my choice. I do a lot of cutting in soft woods and thin woods for model making which requires fine tooth blades. Thin kerf blades work well for me. The saw has to be perfectly aligned with little or no arbor runout.
View CharlesA's profile
CharlesA
3321 posts in 1795 days
#8 posted 12-01-2015 08:31 PM
+1. I think the deflection issue with TK blades is overblown. If I had a beefy, 220v saw, I’d go full kerf, but I don’t, and I don’t really see a problem with cut quality with sharp blades.
I good quality thin kerf blade that s mounted on a saw with low arbor runout that s cutting flat straight wood generally shouldn t need a stabilizer. If you have a saw with excessive runout or a blade that s not quite true, a stabilizer can help, but it doesn t really solve the root problem. I ve never noticed a difference with them or without, so I vote not to bother with them. They don t really hurt anything but your wallet, and they limit cutting height capacity.
A 1/8” full kerf blade does indeed produce more dust than a thin kerf blade….whether or not that s significant depends on you.
- knotscott
View AlaskaGuy's profile
AlaskaGuy
4133 posts in 2306 days
#9 posted 12-01-2015 09:13 PM
No offense meant to the Japanese, this is a true story.
The guy who used to sharpen my saw blades would say this anytime thin kerf blade came up.
”Thin kerf? Those dammed Japanese found a way to sell less material for more money. I wouldn’t have one”
View Julian's profile
Julian
1328 posts in 2687 days
#10 posted 12-02-2015 03:17 AM
I have been using a thin kerf blade for about 13 years and never had a need to use a stabilizer. I have the Forrest WWII blade and cut all types of wood without any issue. If the table saw is in good working order and the blade is not damaged I don’t see why you need a stabilizer. That’s my 2 cents.
-- Julian
View Karamba's profile
Karamba
116 posts in 933 days
#11 posted 12-02-2015 03:48 AM
CharlesA
#12 posted 12-02-2015 03:58 AM
the funny thing about that video is that he is using as his example blades:
1) blades much thinner than standard thin kerf (.069-.070 instead of .091 which is the standard table saw blade)
2) they were from a gang rip saw
3) and the saw was overloaded
I don’t see how any of this relates to normal usage on a standard table saw.
View TheFridge's profile
TheFridge
9455 posts in 1483 days
#13 posted 12-02-2015 04:04 AM
So who uses thin kerfs and would shave a hair off thick stock and trust it?
View rwe2156's profile
rwe2156
2925 posts in 1478 days
#14 posted 12-02-2015 12:58 PM
- 716
Really? Then find an 11” board or cut an inch off another one.
The reason thin kerf blades were made is for low powered machines.
If you’re TS can handle it, you’re always better off with a full kerf blade, IMO.
BTW strips are what you cut, stripes are what you earn ;-)
View 716's profile
716
#15 posted 12-02-2015 07:45 PM
- rwe2156
And now if you do this to make wooden lath to put under stucco on a house you would need to find a lot of “another” boards.
-- It's nice!
