| Forum topic by RetiredCoastie | posted 1237 days ago | 1086 views | 0 times favorited | 20 replies | ![]() |
1237 days ago |
My shop is set up in our 2 car attached garage. The garage is 400 sq ft with 8 ft ceiling. Insulated walls and ceiling. Due to the configuration of my garage and location of my gas line to the house it would be fairly expensive to run a natural gas line for heat in the garage so I’m looking at electric heaters. Do any of you folks have any knowledge or experience with the Cadet “Hot One” heater 30amp version http://www.google.com/products/catalog?sourceid=navclient&rlz=1T4GGIH_enUS260US260&q=the+hot+one+heater&um=1&ie=UTF-8&cid=2592499366584997951&ei=CnI_S_7gCobqMZ_VnbUL&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CBIQ8wIwAg#ps-sellers or the Dayton G73 30 amp heater? http://www.amazon.com/Dayton-G73-Electric-Garage-Thermostat/dp/B000TK2SWO For those with electric heaters, have you had a big jump in electric bills when heater is in use? -- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops |
20 replies so far
#1 posted 1237 days ago |
Any heater that runs on 220 volts is fairly cheap to run, both you choices are good they set up high and the fan pushes the heat down, I would get a rubber floor on the cement where you work more often. We used them a lot in substation cubicles but the floor was uninsulated but we had winter boots on. |
#2 posted 1237 days ago |
How cold does it get in the winter months, I burn mostly wood in the house its a furnace with duct and I have baseboard heaters too and I use them a lot too and my bill did not go up that much, and here it is really cold in the winter months. |
#3 posted 1237 days ago |
I live in south west Washington state, I would say in the winter the temps at night are around 25 to 35 deg F during the day around 35 deg F up to 50s F. -- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops |
#4 posted 1237 days ago |
I also use electric heat….at least I did until my heater died. I ,now, am in the market for a new space heater as well. I bought two cheap heaters from HD and they didn’t cut it so I am returning those and hoping to buy something a little bigger. I think about 1800 watts should do it (that is what my old one was). Mind you I can’t heat it up beyond about 10 degrees C on days like today (-30C) so I kinda don’t go into the shop in weather like this…they were forecasting -35 so I guess I caught a break there :-) How many watts is the ‘Cool One’? The Daytona looks far more substantial. -- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2 |
#5 posted 1237 days ago |
Mark the Hot One comes in two models. The 4000 watt is a 20 amp and the 5000 watt is the 30 amp version. Here is a better link with all the specs. http://www.cadetco.com/show_product.php?prodid=1012 -- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops |
#6 posted 1237 days ago |
I know your talking about electric heat here but have you consider kerosene? I have a 10×30 shop and a 10,000 btu unit that works great. When I’m spraying I bring the temp up with the kerosene heater, shut it off and maint the temp with one of the electric radiator style heaters. -- Ray,VA |
#7 posted 1237 days ago |
Thanks for the input Ray, I had a kerosene forced air heater but in order to use it I had to open the garage door to get ventilation and that defeats the purpose, and I don’t have any windows or entry doors into the garage except the one that goes into the house, plus I don’t want to deal with the fumes. -- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops |
#8 posted 1237 days ago |
I don´t know what electricity cost at yuor place but have you consitered solarwater heating Dennis |
#9 posted 1236 days ago |
Where I live we don’t see the sun much during the winter months, but thanks for the input. -- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops |
#10 posted 1236 days ago |
Thanks for the link on the Hot one. The link shows that they sell them at HD…I’ll have to drive over and check that out. -- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2 |
#11 posted 1236 days ago |
RetiredCoastie its -4 degrees outside and about -6 inside my shop so no woodwork for my just now either Andy -- cut it saw it scrap it SKPE: ANDREW.CARTER69 |
#12 posted 1236 days ago |
Mark try looking on the Internet first, you may be able to beat the price from HD. Let me know how it works out for you if you get the Hot One. Andy that’s too cold for me now, I haven’t seen temps that low since I moved from Alaska, BRRR! -- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops |
#13 posted 1236 days ago |
Is there anyway you can run a duct from your furnace to your garage? They are not as big and bulky as they once were. -- It must be jelly baby, cause jam don't shake like that... |
#14 posted 1236 days ago |
RetiredCoastie – I have the 5000W Hot One in my two car insulated garage and it works great. I got my from Pro Supply Company in Beaverton. Here is the link to the heater on their website. I was able to pick it up at their store, so I didn’t have to pay shipping. -- - Jim, Carroll, OH |
#15 posted 1235 days ago |
Thanks Jim that helps with my decision! It was a toss up between the 5000 watt HOT ONE and the 5000 watt Dayton G73 so I’m going with the HOT ONE. The Dayton G73 is $300.00 on line, I found the HOT ONE at A BOYS in Portland Or. for $229.00 no shipping charge. I’m going to get it in a few minutes. I have an electrical inspector coming tomorrow for the upgraded electrical I did in the garage and now it will all be complete with the addition of this heater and the cable TV outlet I ran this morning. Thanks to everyone that helped with your suggestions. It made the process easier! -- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3551 |
15789 |
Hand Tools
2037 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
