Hickory bowl blank question??
« back to Coffee Lounge forum
Forum topic by Xtreme90 posted 01-02-2010 05:19 PM 893 views 0 times favorited 1 reply Add to Favorites Watch
View Xtreme90's profile
Xtreme90
193 posts in 3190 days
01-02-2010 05:19 PM
Topic tags/keywords: hickory bowl blanks question
Hey fellow lj members??
I have a hickory bowl blank approx 9” diameter and 5” thick. The tree it came from was felled about one year ago. I just cut the blank out of a log that I saved for projects. I put anchor seal on both exposed faces immediatly after I cut it, and left the bark around the edges. My question is when I go to start to turn the blank/ machine it up how do I keep it from cracking?? Should I wait a few more years, and then try to proceed with the project?? I would really like to be able to complete the project now if I could. I have heard that you can rough the blank out meaning remove most of the material and then freeze dry it?? Come back a few months later, and then finish up?
Any advice would help.
Thanks.
-- "I don't cut wood. I machine it!" G.M. The wood machinest
1 reply so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3710 days
#1 posted 08-15-2010 07:06 AM
Its been a long time since you posted this, how did you make out with the blank?
