Help figuring out how to trim log rounds
Forum topic by XquietflyX posted 11-30-2015 03:37 PM 980 views 0 times favorited 24 replies Add to Favorites Watch
View XquietflyX's profile
XquietflyX
339 posts in 984 days
11-30-2015 03:37 PM
I have several log rounds that I need to have consistent dimensions . right now they are not consistently flat and range from 7/8 to one and a quarter or thicker. I need them flat and consistent thickness. I’m trying to decide what the correct tool for this is. I own a belt sander , but as it stands I’ve had a difficult time dimensioning the rounds. I’ve considered buying a power planer, some hand planers or a benchtop planer, however i have yet to see a good method for doing what i need to accomplish. See pics below:
Thanks for any and all advice!!!!!
-Chris
-- You can tell a lot about your wife by her hands, for example if they are around your throat she's prolly pissed off at you...
24 replies so far
View builtinbkyn's profile
builtinbkyn
2364 posts in 964 days
#1 posted 11-30-2015 03:51 PM
How about a router and a jig? Make a jig to hold the slabs. Let the router ride on the top rails of the jig. You can set the router to thickness plane the slabs to your desired thickness.
Here’s one example.
https://www.youtube.com/watch?v=TpU5dZlW2pg
-- Bill, Yo!......in Brooklyn & Steel City :)
View HerbC's profile
HerbC
1763 posts in 2883 days
#2 posted 11-30-2015 03:58 PM
+1 on router jig.
Good luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View Woodknack's profile
Woodknack
11774 posts in 2404 days
#3 posted 11-30-2015 05:26 PM
Drum sander, lathe, or router jig
View bondogaposis's profile (online now)
bondogaposis
4760 posts in 2375 days
#4 posted 11-30-2015 05:43 PM
It will be nearly impossible to plane those w/ a power planer as they are end grain. The above suggestions are better.
-- Bondo Gaposis
XquietflyX
#5 posted 11-30-2015 05:55 PM
The jig idea seems fantastic, i have a good router to use and some good bits. My question with that is how do you do level out surfaces that are not completely flat on one side? if you look at the pieces the cut is not smooth and flat.
View JKMDETAIL's profile
JKMDETAIL
212 posts in 1679 days
#6 posted 11-30-2015 06:10 PM
You may have to flatten one side then flip to mill to desired thickness.
Are these cookies dry. As thin as you are looking at the can curl like a Pringles potato if you are not carful.
View Daruc's profile
Daruc
460 posts in 1156 days
#7 posted 11-30-2015 06:11 PM
Shim it up, flatten one side, turn it over, remove shims, finish.
Need to create a way to hold it in place after shimming.
Check out GaryK’s blog (RIP)
http://lumberjocks.com/topics/1992
View lndfilwiz's profile
lndfilwiz
106 posts in 1624 days
#8 posted 11-30-2015 06:34 PM
+2 router jig!
-- Smile, it makes people wander what you are up to.
XquietflyX
#9 posted 11-30-2015 06:43 PM
i’m totally going to attempt to build a router jig if it works it should help tremendously.
- JKMDETAIL
these are not completely dry but have been drying about 4 or 5 years.
View JoeinGa's profile
JoeinGa
7736 posts in 2031 days
#10 posted 11-30-2015 09:46 PM
- XquietflyX
The SLICES have been drying 4 or 5 years, or the LOGs have been drying 4 or 5 years? Either way, I’d think they should be dry after that long.
And I hope you have more of the uncut logs, because you’ll want to cut them thicker then needed to allow room to flatten and sand them.
XquietflyX
#11 posted 11-30-2015 11:02 PM
The logs have been drying that long.
I have a couple logs drying for this project.
View Fresch's profile
Fresch
244 posts in 1945 days
#12 posted 12-01-2015 12:52 AM
Router with a straight bit, also wax your jig and the router.
View fuigb's profile
fuigb
491 posts in 2981 days
#13 posted 12-01-2015 03:11 AM
+1 on cutting them thicker next time. Give yourself some room to correct an error if the router jig dives deep.
-- - Crud. Go tell your mother that I need a Band-aid.
View mahdee's profile
mahdee
3888 posts in 1791 days
#14 posted 12-01-2015 03:26 AM
If you are cutting them on the band saw, place the log on a flat board and use shims to square one end against the table. Get a 1X and attach it to the end of the log and screw a piece of wood (however thickness you are aiming for) to the top of the 1X that is extending above the log. Use that as a guide to make your cuts.
-- earthartandfoods.com
View Porchfish's profile
Porchfish
824 posts in 2556 days
#15 posted 12-01-2015 12:49 PM
Good idea Mahdee .
-- The pig caught under the fence is always the one doing all the squealing !
