I am refinishing the oak floors in my home.I am using traditional electric Sanders for the main part of the floor, but have been pondering trying to use a hand scraper to do the edges and corners.anyone out there with traditional wood plane experience that could recommend potential tool?
If you are talking about a card scraper, I have heard of some using this for those hard to get to spots. Keep a good hook on it and start in a hard to see area to get the hang of it. I wouldnt recommend this with soft wood floors as soft woods dont work well with card scrapers in my experience.
Paint scraper with carbide blade from the big orange or blue store, the kind with a big handle and the little ball/handhold over the blade end. But PRACTICE someplace inconspicuous before you do anything like a staircase.
For corners, yes. For edges, your hands will be very tired. A regular #4 bench plane set up for smoothing would probably work, If you need to get right up against the wall, a carriage style block or bench plane would do it - the blade goes all the way to the edge of the sole.
Definitely possible. Wood floors were traditionally hand-scraped in their entirety and some people still do it, though it's got to be a lot of work. Not with a card scraper - the usual tool is a ball-joint scraper (Lee Valley sells one with either a steel blade, which is easy to sharpen and burnish a hook, or carbide, which stays sharp for a long time). Or, as dhazelton says, a paint scraper will work too.
I haven't used a carbide scraper much, but when I tried, it didn't feel sharp enough in use. Feeling the edge it seemed sharp but when scraping with it it doesn't work nearly as well as a sharpened tool steel scraper with a hook on it. I can easily take shavings with a steel scraper, but not with carbide for example. Maybe if I took the carbide to the diamond stones it would be different. And maybe for scraping flooring it wouldn't matter.
I have a vintage ball joint scraper, but I wouldn't really want to use it for long. Here's an example: Starrett floor scraper
Plus I would think if you sand one part and scrape another, there's a good chance the difference will show through the finish. I don't have any experience on flooring to tell for sure.
I tried with a card scraper. no good for parquet. Since you have planks of wood flooring I would highly suggest you get the ball jointer. Will save your back. If you want use a belt sander. It will work very well.
Thanks for all the replies - I actually have an electric edging sander like the one pictured. Even with the bag, they create a lot of noise and dust. I've been moving into using antique planes recently, and I was thinking maybe a bullnose plane, or a scraper type plane with a hook built-in to the edge might work well. But when you factor in having to keep the blades sharp with a hook, and the amount of muscle power used, maybe the electric type is the way to go, with maybe just scraping the corners of the room. Some of the heavier handled scrapers with the ball on top looked promising, but I don't know if I want to spend $100 plus to try them out!
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
