Ridgid DP-1550 Drill Press
Forum topic by Viking posted 01-02-2010 01:42 AM 2183 views 0 times favorited 2 replies Add to Favorites Watch
View Viking's profile
Viking
880 posts in 3432 days
01-02-2010 01:42 AM
Topic tags/keywords: drill press protectant mobile base question
Just finished assembly of my new Ridgid DP-1550 Drill Press. Assembly went very well and other than needing a slight adjustment to the motor height to align the motor pully to the quill pulley everything else was in spec. and run out on the quill is almost nill. I promise to do a complete review and pics in a few days after I build a mobile base (looking for some ideas) and drill press table for it.
Question? Do any of you LJ’s have a recommendation of what to use to remove the protectant from the table and other surfaces so I can apply some paste wax? Have same issue on protectant applied to the tables on my new Ridgid JP0610 jointer that was assembled a few days ago.
Thanks in advance for your advice.
Happy New Years to all!
-- Rick Gustafson - Lost Creek Ranch - Colorado County, Texas
2 replies so far
View richgreer's profile
richgreer
4541 posts in 3312 days
#1 posted 01-02-2010 01:47 AM
Buy a steel wool pad for your random orbital sander and use it with some WD-40. I know my local Acme tool store carries the steel wool pads. Not sure about anywhere else.
View syenefarmer's profile
syenefarmer
519 posts in 3318 days
#2 posted 01-02-2010 03:29 AM
Kerosene will take it off in a jiffy. You can buy small bottles of clear kerosene lamp oil at WalMart.
