Short handle gouge
« back to Hand Tools forum
Forum topic by treesner posted 11-30-2015 02:00 AM 545 views 0 times favorited 2 replies Add to Favorites Watch
View treesner's profile
treesner
167 posts in 959 days
11-30-2015 02:00 AM
Hey guys I’m looking for a gouge that’s really short I’ve tried the pfeil (5.5”) and the flex cut but both are to long for my hands to use them prescient with the palm feature. I always end up holding it on the metal because the handle is a bit to long.
Know any that might be shorter?
2 replies so far
View hairy's profile
hairy
2701 posts in 3527 days
#1 posted 11-30-2015 02:33 AM
You might think about cutting down what you have. It would be easy if you can get the tool out of the handle first. I would put the steel in between 2 pieces of wood and put that in a vise and drive the handle off. Put a piece of wood against the handle and drive it off with a hammer.It should survive the removal and go back on. It’s probably pressed in.
Or make a new handle.
-- My reality check bounced...
treesner
#2 posted 11-30-2015 04:35 AM
You might think about cutting down what you have. It would be easy if you can get the tool out of the handle first. I would put the steel in between 2 pieces of wood and put that in a vise and drive the handle off. Put a piece of wood against the handle and drive it off with a hammer.It should survive the removal and go back on. It s probably pressed in.
- hairy
Yeah I was sort of thinking about that or whittling down the handle
Also looking at the flex cut that interchange, maybe just cut it down
