Unwanted bows in a jointer
Forum topic by Konomigon posted 1240 days ago 967 views 0 times favorited 6 replies Add to Favorites Watch
View Konomigon's profile
Konomigon
55 posts in 1399 days
1240 days ago
HI All and Happy New Year!
I am having a problem with my jointer. Its a small six inch delta bench top model, JT160 I think. Anyway, it seems to cut very smooth, but the problem is that I cannot get a flat edge. When I put two jointed edges together there is up to a 1/16 inch gap in the middle. The ends seem to meet up though.
It seems to work ok with smaller lenghts, about 15 inch boards, but I’m trying to joint boards for a table top, maybe 50 inches long. Is this too long?
Any suggestions???
Thanks in advance!
-- Kris
View Russel's profile
Russel
2199 posts in 2112 days
#1 posted 1240 days ago
I have a Delta benchtop jointer as well, and I’ve found that 50 inches is too long. There just isn’t enough consistent support to get a good edge. I haven’t had reliable results with anything over 36 inches.
Konomigon
#2 posted 1240 days ago
Thanks for the advice. I kind of had a feeling that this was the case :(
-- Kris
View skidiot's profile
skidiot
50 posts in 1818 days
#3 posted 1240 days ago
There was a thread the other day about this problem. They said if you carefully set up a roller stand on each end of your jointer you can joint boards of any length.
-- skidiot northern illinois
Konomigon
#4 posted 1240 days ago
Thats a great idea! I have been meaning to get some of those for other uses too. The only problem I have is that basement/workshop is very uneven. It is an old dirt basement that the previous owners had bricked and then very hastily covered with a very thin layer of cement. I think I could find a good place for it with some shims and a careful setup.
-- Kris
12083 posts in 1514 days
#5 posted 1240 days ago
check your outfeed table ,
if it is not dead on with the cutterhead ,
it wont cut absolutely flat .
to high , and the wood is crowned in the middle ,
to low , and it is bowed in the middle
View bhack's profile
bhack
347 posts in 1893 days
#6 posted 1240 days ago
I have the same machine. As patron said the first thing to check is the cutters even with the outfeed. I aligned mine with a dial indicator and get very good joints. If the board is longer than thirty inches or so be sure to keep constant pressure (on infeed and outfeed) while feeding.
-- Bill - If I knew GRANDKIDS were so much fun I would have had them first.
