Turning bandsaw blade inside out?
Forum topic by apopj posted 01-01-2010 09:36 PM 6302 views 0 times favorited 19 replies Add to Favorites Watch
View apopj's profile
apopj
8 posts in 3064 days
01-01-2010 09:36 PM
Hello all,
Well, ran down to Harbor Freight and found a 3/4” blade on sale for $6…. bought it and am going to put it on my Delta 14” bandsaw. Problem is, it’s inside out, the teeth face the guide bearings!! This is a woodworking blade, it’s just become inside out, probably by me taking it out of the package or some such.
So, how do I turn it “inside out” again so it will face the right direction?
Thanks for the help….
Jeff
-- I ride waaaay too fast to worry about cholesteral
19 replies so far
View RetiredCoastie's profile
RetiredCoastie
999 posts in 3152 days
#1 posted 01-01-2010 09:51 PM
Turn your saw around…. sorry I couldn’t pass it up. I’m assuming that if you took the blade off and installed it with the teeth facing out the teeth would be upside down, then I would think you could take the blade with gloves on and twist the blade inside out. If not then I would take the blade back to Harbor Freight. I don’t think Ive ever heard of this happening.
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
View papadan's profile
papadan
3584 posts in 3338 days
#2 posted 01-01-2010 09:56 PM
Just like Coastie said, hold it with gloves and give it a twist. LOL
View bent's profile
bent
311 posts in 3639 days
#3 posted 01-01-2010 10:19 PM
it’s easiest if you fold it over into a figure 8, double it up on itself, then undouble it in the oppsite direction. be careful, it will spring back into shape! if you’re lucky, you can toss it away from yourself (in an open area) and uncoil it at the same time so that it doesn’t spring back in your hands.
View LesB's profile
LesB
1688 posts in 3413 days
#4 posted 01-01-2010 11:39 PM
As these fellows have said just put on gloves and twist it inside out.
Next, if you want to store bandsaw blades in small circles (1/4 the size of the open blade) take hold of the blade at two opposing points and twist each in the opposite direction, follow through and flip over. The blade will coil up into a tight circle.
-- Les B, Oregon
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3555 days
#5 posted 01-01-2010 11:42 PM
Wow are you sure that blade is not for the saw in the opposite room?Alistair
View ChunkyC's profile
ChunkyC
856 posts in 3224 days
#6 posted 01-01-2010 11:44 PM
Here’s a video from Stu’s Shed showing exactly how to do it:
http://www.youtube.com/watch?v=2DbbwN
you have to get toward the end of the video for turning right side out.
cc
-- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135
View poopiekat's profile
poopiekat
4349 posts in 3704 days
#7 posted 01-02-2010 12:43 AM
The blade was probably made for HF’s Butcher Band Saw, which has a mirror-image configuration. The operator stands to the left of the blade. The blade runs counter-clockwise, too. I always wondered, by the wy, if anyone is using one of these saws for woodworking? They seem to be made really rugged, and most have a nice sliding table for cross-cutting pork-chops…or lumber!
View northwoodsman's profile
northwoodsman
242 posts in 3716 days
#8 posted 01-02-2010 01:22 AM
It’s made for the southern hemisphere.
-- NorthWoodsMan
apopj
#9 posted 01-02-2010 01:49 AM
Thanks for all the help guys…. the video showed my just what I needed to do… alas, the blade was too short. I purchased it at HF and it said 93”... well, as many of you know, the Delta takes 93 1/2” and this one was just a little too small to use. Oh well, live and learn…
Thanks again for all of the replies…
Jeff
poopiekat
#10 posted 01-02-2010 02:16 AM
Was it an 82” blade? The HF meat saws are 82” check this: http://www.tor-rey-usa.com/foodequipment/meatsaws/ST-295-AI.pdf I don’t really understand why the throat is on the left side on most meat saws, rather than the right like on woodworking bandsaws. But this would explain the reversed cutting edge.
apopj
#11 posted 01-02-2010 02:37 AM
Nope, 93” but thanks for the input
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3076 days
#12 posted 01-02-2010 05:13 AM
Naww, you’re all wrong. Works great anywhere south of the equator.
papadan
#13 posted 01-02-2010 08:46 PM
Crossing the equator kinda shrinks it huh? LOL
View ChrisMc45's profile
ChrisMc45
100 posts in 2829 days
#14 posted 03-20-2012 08:44 AM
The previous link to the Stu’s Shed video kicked out as “malformed video ID” (???)
“http://www.youtube.com/watch?v=2DbbwNqiY7o&feature=colike” is an update.
All joking aside, I got a HF bandsaw blade backwards, inside-out, whatever we call it. The video squared me away perfectly. I must admit I was being somewhat fearful of the coiled bandsaw blade; Stu made it look easy and well controlled, so now I can do it as well.
View MoshupTrail's profile
MoshupTrail
304 posts in 2450 days
#15 posted 03-20-2012 10:35 AM
There’s a couple of ways to do that. Pretty neat!
How to Fold a Band Saw Blade
-- Some problems are best solved with an optimistic approach. Optimism shines a light on alternatives that are otherwise not visible.
