Table saw trouble
Forum topic by MikeOB posted 01-01-2010 08:47 PM 1602 views 0 times favorited 13 replies Add to Favorites Watch
View MikeOB's profile
MikeOB
89 posts in 2992 days
01-01-2010 08:47 PM
I have a Delta 36-978…everything was fine last night and when I went to do my next cut I lost all power. The breaker and outlets have power, so it has to be somewhere on the saw. I unscrewed the switch and all seemed well there.
I did press the overload button but nothing seemed to happen.
Any suggestions where I should look on the motor?
-- Mike, Portage, WI
13 replies so far
View PurpLev's profile
PurpLev
8534 posts in 3519 days
#1 posted 01-01-2010 08:51 PM
do you have an ac meter? did you check to make sure power is going through the switch? I know you said that you unscrewed the switch and it seemed ok – but I didnt get from that if you meant visually – or if you actually checked it with a meter.
another thing to try is to take the belt off the pullies, let the motor run on its own (given that it does start) this will take the pullies, and blade assembly off the equation.
MikeOB
#2 posted 01-01-2010 09:08 PM
I do not have an ac meter…I took off the switch to check to see if something loosen up. I will try the belt thing next.
View MarkwithaK's profile
MarkwithaK
370 posts in 3048 days
#3 posted 01-01-2010 09:25 PM
With no electrical meter troubleshooting an electrical motor can be tough. You can use a jumper wire across the switch terminals to check the switch itself. Not familiar with your saw’s motor but if there is a capacitor and it has either failed or gotten weak then a meter that can test the capacitance would be needed. Of course the worse case scenario would be that the motor has failed.
-- If at first you don't succeed then maybe skydiving isn't for you.
View RetiredCoastie's profile
RetiredCoastie
999 posts in 3053 days
#4 posted 01-01-2010 09:56 PM
Is it set up for 110V or 220V?
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
MikeOB
#5 posted 01-01-2010 10:11 PM
110v now was going to switch it to 220V but I wanted to cut a few pieces 1st.
View KnotWright's profile
KnotWright
258 posts in 3358 days
#6 posted 01-01-2010 10:14 PM
Mike, since the motor looks to have a capacitor sounds like that’s what’s bad. You can disconnect the saw from the power source, and take off the cover to the capacitor and see if it smells burnt, or looks like its melted, those both are good signs its time to replace it. If you don’t have your owner’s manual, here’s a link to it for you.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A18825,36-978%2036-979.pdf
-- James
TopamaxSurvivor
18161 posts in 3546 days
#7 posted 01-02-2010 05:35 AM
If you feel comfortable doing it, turn it on and give it a spin using the belt. See if it takes off.
View BlankMan's profile
BlankMan
1490 posts in 3224 days
#8 posted 01-03-2010 04:15 AM
Mike how goes it with the saw? If it is the capacitor I was at the Milwaukke Habitat For Humanity Restore the other day and they had a bin of motor capacitors for $3 and $5. Thet were 15mfd and 24mfd 400V. If one of them is the right value and that’s the problem I could pick one up and send it to you.
-- -Curt, Milwaukee, WI
MikeOB
#9 posted 01-04-2010 12:08 AM
yahoo it is fixed!
My friend’s father came over with his meter and found out it was in the switch. Somehow grease go inside it…cleaned it, fired it up and away we go!
View Stewy's profile
Stewy
33 posts in 2961 days
#10 posted 01-04-2010 12:38 AM
Be careful messing with the capacitor as they store electricity and can shock you after the power is off.
You might already know this but just a reminder. good luck
-- Dennis in Iowa "You can have 30 years experiance or 1 year 30 times!!!!"
View Brian024's profile
Brian024
358 posts in 3271 days
#11 posted 01-04-2010 02:05 AM
You got that right Dennis, that how the high school electrical teacher keeps his kids from sleeping in class, yes its mean and dangerous but I don’t think he’s had a kid sleep in his class that last couple years.
Stewy
#12 posted 01-04-2010 02:13 AM
I was an electrician and electronic tech for over 28 years and I got bit a few times myself!!!!!!!
We had a guy that liked to charge one up and toss it to the new guy so when he caught it POW.
13594 posts in 3212 days
#13 posted 01-04-2010 02:22 AM
i had a ras once with a reset button on it ,
after i got tired of trying every thing ,
i REALLY PUSHED it , like a tap with a hammer ,
it started right up !
