10" tool grinder
Forum topic by bigike posted 01-01-2010 05:20 AM 1028 views 0 times favorited 4 replies Add to Favorites Watch
View bigike's profile
bigike
4052 posts in 3288 days
01-01-2010 05:20 AM
Topic tags/keywords: grinder 10 delta
Quick question, i was wondering i have a 10” grinder from delta but i really don’t like the cove/hollow gring it puts on my chisels and plane blades. I like the cove or hollow gring a 6” wheel puts on my tool blades, question is. Can i put a 6” wheel on my grinder or will this not spin right/true? Iforgot to mention it’s a VS grinder meaning u can change the speed from fast to slow.
TopamaxSurvivor
18271 posts in 3675 days
#1 posted 01-01-2010 05:33 AM
I don’t know of any reason it wouldn’t work as long as the spindle is the right size for the wheel.
View PurpLev's profile
PurpLev
8535 posts in 3648 days
#2 posted 01-01-2010 05:45 AM
should work well, esp. if it’s a VS.
to make sure – check the RPM a 6” grinder runs at -it’s always stated on the specs of the machine. but I dont see any reason you’d have any issues. again – esp if yours is a VS
View jack1's profile
jack1
2107 posts in 4027 days
#3 posted 01-02-2010 12:33 AM
To be sure try your least favorite chisel that you were going to replace anyway. But if the arbor is the same or you can use a spacer, should be fine with the VS unless the lower end is too fast. I think white stones are the best for that sort of thing also.
View 1yeldud1's profile
1yeldud1
301 posts in 3041 days
#4 posted 03-02-2010 11:35 PM
You NEED to check the RPM of your grinder and compare it to the wheel you are installing on it. Having seen several wheels explode on pedistal grinders over 35 years of being a tool maker I can say it is UGULY. The RPM of the wheel MUST be rated above the RPM of the GRINDER to make it safe !!!!!!
