| Forum topic by Mario | posted 312 days ago | 232 views | 0 times favorited | 6 replies | ![]() |
312 days ago |
Topic tags/keywords: fire extinguishers I am trying to finish putting my shop together and sought the advice of a fire marshal to determine what I needed to have for fire supression. Turns out I need to have at least 4 extinguishers, 3 10 pounders and at least 1 5 pounder. How many do you have in your shop. After he left I realized that I did not ask him about smoke detectors? -- Hope Never fails |
312 days ago |
First a quick comment on smoke detectors… I know there are two varieties, one that is lower cost but is often tripped by high humidity/dust, and another higher-cost type. I wish I knew their identifying name so I could tell you, but thought you should look into the differences between the two before you buy something for your soon-to-be-dust-filled shop. As for extinguishers… I have to admit I don’t have one in the shop, but then again my shop is a garage, and I do this as a hobby. The fire extinguisher I own is in the kitchen! -- Dekker - http://www.WoodworkDetails.com/Blog/MNagy/ |
312 days ago |
Hi Mario, I think a smoke detector would be a good idea. I am not sure how the dust may impact the performance of a smoke detector over time. Dalec |
312 days ago |
uh oh. oh Santa, dear… -- "Functional WoodArt" by Debbie, Canada (http://www.execulink.com/~yohan) |
312 days ago |
I have a smoke detector and (1) 5lb dry chemical extinguisher. I also volunteer for a Fire Dept. that is 4 miles away and carry a good insurance policy. If it burns, there are photos too. Also, keep your chemicals in a paint locker…like I used to. ??? Really; I need to build a new paint locker. A good tip would be to think of where a fire will start if one was going to. What’s plugged in? Where are all those old oily rags? Most of us work out of our garages…so, where do you keep your gas? Hell! Where’s the lawnmower? Can you hear your smoke detector when it goes off? From inside the house? While your in bed with the bedroom door closed? I can’t. Makes it just about worthless huh? I know you have already thunk this all out but there are those who continue to use the bench grinder over a gas can. I know you are not one of those guys. I see your shop pic. It’s a large outbuilding…pole barn style. You’d probably do best with a separate alarm service to monitor not only for fire but also for theft. If it’s a public type shop with “employees” you’d best take the Fire Marshalls advice. Any chance of killing the power on the way out the door at night? -- Bob Vila would be so proud of you! |
311 days ago |
Thanks Dadoo, thank you for the other advice, it is alway nice to have experts look at things as they tend to see things that we may miss. -- Hope Never fails |
309 days ago |
Hi Mario, These all are very good and necessary ideas and suggestions. Smoke alarms and alarms for temp changes, together with the right kind of emergency fire extinguishers, located in the proper positions, are a MUST. They need to be part any shop environment. But they are just that, emergency devices – not ment to deal with a worst case senario. My suggestion – Take the next step, as I did. Sit down and speak with your insurance agent. Make certain that your shop and your equipment is properly insured. Most homeowner policies have specific requirements for outbuildings and specific limits for their contents. When I talked with my broker, I was able to buy an “all risk” replacement rider for the building and its contents, which took over after the limits of my homeowner’s coverage for a surpisingly small annual premium – well under the cost of a couple of good table saw blades. -- Bob |
| Sponsor | Forum | Topics |
Woodworking Skill Share
1146 |
1533 |
105 |
301 |
96 |
Woodworking Trade & Swap
211 |
Coffee Lounge
839 |
LumberJocks.com Site Feedback
256 |
