Drafting Table
Forum topic by ronstar posted 11-28-2015 03:27 PM 1162 views 0 times favorited 7 replies Add to Favorites Watch
View ronstar's profile
ronstar
474 posts in 3797 days
11-28-2015 03:27 PM
I’d like to build a drafting table similar to this.
But I’m stuck as to how to secure the iron diagonal pipe supports to the legs. Anyone have any ideas?
-- Ron, Northern Illinois
7 replies so far
View conifur's profile
conifur
955 posts in 1238 days
#1 posted 11-28-2015 03:32 PM
Pins?
View johnstoneb's profile
johnstoneb
2995 posts in 2259 days
#2 posted 11-28-2015 03:35 PM
Use wood and mortise and tenons
-- Bruce, Boise, ID
View builtinbkyn's profile
builtinbkyn
2624 posts in 1027 days
#3 posted 11-28-2015 03:41 PM
Just a guess, but those diagonal iron supports probably run through the bottom of the foot and have threaded ends and a nut. They probably just pierce into the vertical leg and butt end into the wood. Mortise and tenon connection at the leg is loose fitted and not glued. The iron rod holds this together.
The whole assembly looks like it was designed to be broken down for shipping/moving, with those wedged connections on the stretchers. Very nice design.
-- Bill, Yo!......in Brooklyn & Steel City :)
View SawSucker's profile
SawSucker
110 posts in 1015 days
#4 posted 11-28-2015 04:30 PM
I have an antique drafting table that is somewhat similar, that does not require diagonal leg supports. I also have an antique drafting arm for it.
View Slemi's profile
Slemi
117 posts in 1627 days
#5 posted 11-28-2015 07:18 PM
View MrUnix's profile
MrUnix
6848 posts in 2285 days
#6 posted 11-28-2015 07:47 PM
Wood screws, small lags, through bolted with nuts on the bottom… lots of ways. Doesn’t sound like much of a problem really. I have one that is very similar to the one shown, and as already mentioned, it uses wood instead of pipes.
ronstar
#7 posted 11-28-2015 11:27 PM
Thanks everyone for the advice! And I think I’ll do it all in wood with mortise/tenons – and I’ll try to get close to the one made by Tom Fidgen as posted by Slemi.
