Shellacing end grain.
Forum topic by Dogfisher posted 11-26-2015 05:00 PM 915 views 0 times favorited 9 replies Add to Favorites Watch
View Dogfisher's profile
Dogfisher
11 posts in 1153 days
11-26-2015 05:00 PM
Topic tags/keywords: rustic arts and crafts finishing miter saw question
I have a end table project that incorporates 3/8” discs cut from downed limbs of various species and size. I’ve arranged them on a plywood tabletop and plan on grouting in between them. I’ve shellaced them about 8 times but they keep drying with shiny parts and dull parts. I’m assuming that they’ll eventually stop absorbing but I’m concerned about the too coats not having a smooth finish. I sand down the high points in between coats. Any advice for applications would be greatly appreciated!
https://s3.amazonaws.com/vs-lumberjocks.com/nyegr51.jpg!
-- RMiller, New Jersey, http://inflatus1.wix.com/rsmiller
9 replies so far
View Andre's profile
Andre
2371 posts in 2046 days
#1 posted 11-26-2015 05:06 PM
I have found that sanding and Shellac don’t work all that great, I usually plane end grain smooth and Shellac goes on much better.
Dogfisher
#2 posted 11-26-2015 06:05 PM
I’m meant “top coats” in my first post. Planing is not an option for me.
View michelletwo's profile
michelletwo
2773 posts in 3255 days
#3 posted 11-26-2015 06:18 PM
iF I understand correctly, then andre is correct..you are trying to shellac end grain discs. Are they all dry as a bone? Is there a big difference between the heartwood and sapwood? Between the different species? Shellac would have trouble with these differences in the wood.
Dogfisher
#4 posted 11-26-2015 06:49 PM
They were pretty dry when I started. They dry spots are erratic. Not restricted to heart wood. I’m just trying to figure out if there is a trick to getting the top coat smooth. There should be a point when the discs stop absorbing. Then hopefully the coats will be more even drying.
View John Stegall's profile
John Stegall
514 posts in 3756 days
#5 posted 11-26-2015 06:57 PM
I read that you can do a sand with a very fine grit (400) and this was supposed to reduce the absorption. The purpose of this was to finish a table top so that the face grain and end grain would look the same. It might help.
-- jstegall
View gfadvm's profile
gfadvm
14940 posts in 2930 days
#6 posted 11-27-2015 01:28 AM
I finished some old growth redwood end grain that I had the same issues with: the early wood and late wood absorb finish at different rates (my redwood was like shellacking a sponge). I just kept applying more shellac, sanding lightly with 320 grit, and it eventually came out very even.
Dogfisher
#7 posted 11-27-2015 02:57 AM
Awesome. That’s what I wanted to hear.
gfadvm
#8 posted 11-27-2015 03:23 AM
Click for details
This is one of 2 redwood bandsaw boxes I finished with shellac.
Dogfisher
#9 posted 11-27-2015 05:10 AM
Nice work.
