What kind of bits are these?
Forum topic by Rick_M posted 11-26-2015 06:26 AM 1128 views 0 times favorited 11 replies Add to Favorites Watch
View Rick_M's profile
Rick_M
10851 posts in 2257 days
11-26-2015 06:26 AM
Some kind of Forstner bit but I’ve never seen ones exactly like these. Some have almost no point then one has a really long point.
-- http://thewoodknack.blogspot.com/
11 replies so far
View oldnovice's profile
oldnovice
6484 posts in 3244 days
#1 posted 11-26-2015 06:43 AM
The top one looks like a Forstner bit and the lower one looks like an auger bit, like one would use in a brace.
The bottom bit has no edge cutting capability like the Forstner bit.
Both look a little rusty and worse for the wear.
I have some like both of those!
That’s just my opinion …. but I could be wrong!
Rick_M
#2 posted 11-26-2015 06:55 AM
- oldnovice
The bottom one does actually have an edge cutter, it’s just hidden by the spur point; bad angle on the photo.
Top one is definitely a Forstner I’ve just never seen one with such a small point, almost nonexistent. It would make a nearly perfectly flat bottomed hole. I’ll test them tomorrow and we’ll find out.
View TheFridge's profile
TheFridge
8675 posts in 1362 days
#3 posted 11-26-2015 07:06 AM
Forstner looks similar to a barefoot auger. End grain for both maybe? Only reason I’d think for it to have no Spurs?
View GerryB's profile
GerryB
69 posts in 2458 days
#4 posted 11-26-2015 07:21 AM
Or, is the spur broken (or worn off) on the one?
-- The pursuit of excellence is gratifying and healthy. The pursuit of perfection is frustrating, neurotic, and a terrible waste of time. Edwin Bliss
View jerryminer's profile
jerryminer
851 posts in 1318 days
#5 posted 11-26-2015 07:23 AM
Top one looks like a Forstner.
Bottom one looks like a Stanley “Power Bore” bit—-a discontinued line. (Clean up the shank and you may find the Stanley logo). Lee Valley sells a similar bit, called a “Greenwood Bit”
View MarcusM's profile
MarcusM
57 posts in 2857 days
#6 posted 11-26-2015 02:31 PM
What size is that top one? Looks very much like a euro-hinge cup boring bit.
Regards, Mark
-- Tilbilly Mark
View mjn's profile
mjn
9 posts in 2968 days
#7 posted 11-26-2015 03:37 PM
some old boat building bits would not have screws , ect. end grain , boring would follow the grain with screw type auger .
View CO_Goose's profile
CO_Goose
166 posts in 1667 days
#8 posted 11-26-2015 03:42 PM
The top one looks like a fly cutter for a milling machine. Something to level out a surface.
-- Just making sawdust
Rick_M
#9 posted 11-26-2015 08:44 PM
- GerryB
No, it’s part of a set, they are all the same.
- jerryminer
Bingo! I think you’ve pegged it.
Regards, Mark
- MarcusM
1-5/8”, it’s part of a set. I don’t have all of them but the smallest is 3/8”, largest is 1-5/8”.
View DKV's profile
DKV
3940 posts in 2381 days
#10 posted 11-26-2015 10:55 PM
3939
-- This is a Troll Free zone.
Rick_M
#11 posted 11-27-2015 04:04 AM
After cleaning up the bits I believe they were probably modified, the spurs ground off. Only 2 have readable markings, one is made in china and is very different than the rest, the other is Connecticut Valley Mfg. Co..
