Finishing solid maple slab table top.
Forum topic by GeordieY posted 11-25-2015 08:53 PM 1069 views 0 times favorited 11 replies Add to Favorites Watch
View GeordieY's profile
GeordieY
7 posts in 823 days
11-25-2015 08:53 PM
I’ve been researching finish options for a table I’m building, but would like some input from people with more experience, as I have very little in regards to finishing.
The table is made from 2 kiln dried, live edge, maple (not sure if it’s soft or hard, but I’m inclined to go with soft after working with it) slabs.
The table will reside in an enclosed porch that 50% of the time (when we’re not home) will not be climate controlled (it has a window-rattler AC unit and 2 large sliding glass doors open it to the inside of the house) in the state of Florida and surrounded by windows with sheer curtains, so UV may be an issue.
Given that it will often be hot, it will see a fair amount of indirect sunlight, and the humidity levels will be subject to fluctuation, I was leaning towards treating the table as an outdoor table. The wife also wants a gloss finish, and I personally don’t want to re-apply finish very often if ever, and have concerns about the top being marred from normal use (board games, family dinners, drunks). I would also like a natural-ish finish that makes the grain pop like oil.
So far, I’ve come up with 3 possibilities: Epifanes Clear Varnish (concerns with top marring), oil followed by bar top epoxy (concerns with epoxy adherence due to oil and how much the epoxy yellowing from the sun will affect the look), and 1/3 BLO, 1/3 Helman’s Spar Varnish in gloss, and 1/3 mineral spirits (concerns with top marring).
Thank you in advance for your words of wisdom,
George
11 replies so far
GeordieY
7 posts in 823 days
#1 posted 11-25-2015 09:11 PM
It could be that I can finish it like an indoor table and not worry, I’m just uncertain. Any suggestions would be helpful.
View conifur's profile
conifur
955 posts in 1054 days
#2 posted 11-25-2015 09:14 PM
I would not like the epoxy look personally, your 3rd option I think is the best but dont know how glossy it will be, but very reparable. That would need to be done on a sample piece.
View JayT's profile
JayT
5522 posts in 2114 days
#3 posted 11-25-2015 09:44 PM
I’d test the last finish before committing to it. Personally, I don’t like BLO on maple—it makes it too yellow. I’d use a good spar urethane for the final finish. If you are wanting to bring out the grain, either a different oil, like tung oil or a seal coat of shellac. Test a few and see what makes the grain look like what you want.
The spar won’t be the easiest to touch up, but will be very durable and tough, so you probably won’t have to.
View gfadvm's profile
gfadvm
14940 posts in 2593 days
#4 posted 11-26-2015 01:51 AM
The wiped on Spar will give you the look and protection you are after IF you do 6-8 coats and IF it does not get direct sun. Omit the BLO in the Spar mix as it already contains long oils that will give the same result as applying BLO. I wipe on 2-3 parts Spar to 1 part MS on a lot of my projects.
View Aj2's profile
Aj2
1272 posts in 1700 days
#5 posted 11-26-2015 02:27 AM
Here’s my suggetions it does come in gloss and semi gloss.Its much like paint without color.
-- Aj
View ThomasChippendale's profile
ThomasChippendale
244 posts in 835 days
#6 posted 11-26-2015 03:20 AM
General finish exterior 450, its what the desk I am writing this is finished and I was just thinking how tough this finish is. For added gloss you may want to apply 6 to 8 coats and use a sealer to cut down on the number of coats.
-- PJ
GeordieY
7 posts in 823 days
#7 posted 11-26-2015 11:19 PM
Thanks for the input fellas. I think I’ll cut the table to length then try both spar and general 450 on the scraps before deciding. I’ll post the project when it’s done.
View Clint Searl's profile
Clint Searl
1533 posts in 2264 days
#8 posted 11-27-2015 03:11 AM
Anything but a BLO concoction!
I would go with a waterborne gloss floor finish like Varathane or Bona Mega.
View DMC1903's profile
DMC1903
285 posts in 2230 days
#9 posted 11-27-2015 07:40 AM
I’ve used General Finishes outdoor oil and had terrible results, it looked great for several months. However, it started to peel and flake off. Now all of the outdoor furniture gets 5-7 layers of Epihanes. Never had any issues!
Best of luck.
GeordieY
7 posts in 823 days
#10 posted 11-27-2015 04:52 PM
Keep in mind that this isn’t neccesarily an outdoor table. The enclosed porch has walls and windows, and when we’re home it’s open to the inside of the house. I’d like it to last, and look good. It’s entirely possible that an interior finish could do the job in these conditions.
GeordieY
7 posts in 823 days
#11 posted 11-30-2015 07:08 PM
What about Waterlox or one of the Sutherland Welle’s Murdoch’s products (hard oil, sealer, table top)?
