Guys I need some help: standing desk design idea
Forum topic by Makakio posted 11-25-2015 03:24 AM 1094 views 0 times favorited 14 replies Add to Favorites Watch
View Makakio's profile
Makakio
2 posts in 908 days
11-25-2015 03:24 AM
Hello all -
Need to raise this battleship by 14” and make it a standing desk. Aesthetics aren’t really important – a solid design to adding 14” risers to each side will be the key. Currently I’m thinking about adding solid 2x material below the sides for the height and sandwiching it on both sides with some plywood and then drilling through to sandwich the joint.
Thoughts?
14 replies so far
View iminmyshop's profile
iminmyshop
284 posts in 1987 days
#1 posted 11-25-2015 03:28 AM
It would not be pretty but you can build a riser the same way a wall is built. Make believe it is a small wall just 14” tall and cover the sides with 1/4” plywood. You could then finish the sides however you liked.
-- http://www.alansfinewoodworking.com/
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1568 days
#2 posted 11-25-2015 05:55 AM
why not screw some 3/4” ply to the sides,the height the sides are now plus 14”,then if you care, veneer over the screws.
View JeffP's profile
JeffP
573 posts in 1385 days
#3 posted 11-25-2015 11:57 AM
If aesthetics are not important, go “college style” with it. We used to raise our beds to create storage underneath…by putting a beer can under each leg.
I reckon it would take about 100 beer cans to raise this 14”.
There’s lots of football on TV during the next week…should be able to get a good start on that.
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
View rwe2156's profile
rwe2156
2916 posts in 1474 days
#4 posted 11-25-2015 04:05 PM
4 notched 3×3’s either on outside or inside of panels.
View ChefHDAN's profile
ChefHDAN
1062 posts in 2843 days
#5 posted 11-25-2015 04:36 PM
If you don’t need the entire surface raised to standing height, you can also make a riser to put on top of the base desk. Looks like a large wall mounted monitor, which could get funky, but for me I’ve got a 18” x 36” top with a 16” base, keyboard is wireless and the monitor has enough cord so I just move what I’m working on up so I can stand.
View Richard H's profile
Richard H
489 posts in 1674 days
#6 posted 11-25-2015 04:53 PM
How hard would it be to take the sides off the desk and just replace them with longer new ones?
You might end up having to refinish the entire table to make it all match but if you really wanted to be picky you could probably make it look like it was built that way or at least close to it.
View Daruc's profile
Daruc
460 posts in 1126 days
#7 posted 11-25-2015 06:05 PM
Not worried about aesthetics?, Just bolt 2- 2×4’s to each leg (on the inside) done!
If you wanted, you could bullnose or round over the 2 sides of each 2×4 and stain them to match for a better look.
That would be plenty strong enough.
View MT_Stringer's profile
MT_Stringer
3168 posts in 3225 days
#8 posted 11-25-2015 08:09 PM
- daddywoofdawg
I like this idea. Should be easy and fairly cheap. Maybe through bolt each piece in at least four places with 1/4 inch bolts, washers and nuts. Two pieces of 3/4 inch plywood cut to approximately the width of the sides and about 24 inches in length will provide the needed height and room to secure it to the side.
That should be plenty sturdy. The desk will provide the needed stability.
View alittleoff's profile
alittleoff
539 posts in 1270 days
#9 posted 11-25-2015 08:27 PM
Get the maple or birch finish cabnet style plywood, and I think you will have a close match to what
you have now.
Gerald
alittleoff
#10 posted 11-25-2015 08:27 PM
Get the maple finish cabnet style plywood, and I think you will have a close match to what
you have now.
Gerald
Makakio
2 posts in 908 days
#11 posted 11-30-2015 05:21 PM
THANK YOU THANK YOU all!
Apologies for the delayed response but Thanksgiving travel took over.
Much appreciated advice and I’ll take a photo once done and post it here for (what is certain to be) your amusement…
View bondogaposis's profile
bondogaposis
4717 posts in 2345 days
#12 posted 11-30-2015 05:45 PM
Cement blocks.
-- Bondo Gaposis
View dhazelton's profile
dhazelton
2766 posts in 2290 days
#13 posted 11-30-2015 07:31 PM
Cut a hole about 14 inches deep into the floor, stand in there and leave the desk alone. Like the Jerry Lewis movie – ‘Don’t Raise the Bridge, Lower the River.’
View Underdog's profile
Underdog
1095 posts in 2029 days
#14 posted 12-08-2015 03:50 AM
Here's what I'm doing.
Might be a bit overkill for what you want though. You might find it interesting nonetheless.
-- "woodworker with an asterisk"
