Table saw blades: forrest, freud, ridge carbide?
Forum topic by ben posted 349 days ago 562 views 0 times favorited 10 replies Add to Favorites
View ben's profile
ben
154 posts in 357 days
349 days ago
After doing more burning than I would like, I am doing 2 things: getting a splitter that I can use when the blade guard is off, and getting a second blade (still using the bosch blade that came with my 4000). Anybody have any thoughts on particular blades? Seems like everybody raves about the WW2, and I’ve caught a few people who like the ridge carbide TS2000.
Also, I will be doing a fair bit of ripping of long 2-by’s… Any suggestions for a cheap/durable blade to match?
Thanks.
-ben
View coloradoclimber's profile
coloradoclimber
319 posts in 554 days
349 days ago
Ben,
For the ripping, do you want a glue ready face or are you just wanting to split some 2×4s to use in framing or as preliminary stock? I tend to swap between blades and I have my “good” blades, including ripping blades, and my “good enough” blades.
For ripping 2 bys, pressure treated, junky ply, composite board, etc, I have a couple old 28 and 40 tooth Vermont America blades or I use a worm drive circular saw. I keep the blades clean, feed at a reasonable rate, and I don’t worry about ruining a $50 – $100+ blade. I’ve been very happy with this combination but both options leave a face that is far from ready for glue-up.
For cleaner cuts I use either freud or forrest. Both the Freud and Forrest work well, clean, pretty much glue ready faces. I’ve not used the ridge carbide but have read good reviews.
For my junkier blades, blades that are going to be fed a wide variety of god knows what, I use standard kerf. For my “good” blades I’ve been going pretty much exclusively with thin kerf blades and have been happy.
View SilverFoxArt's profile
SilverFoxArt
27 posts in 368 days
348 days ago
Ben, for your finish cuts, “Ready to glue” what tooth count do you use?
-- Mel, Utah, SilverFoxArt.com
View ben's profile
ben
348 days ago
ebanista: unfortunately, there is little that I can do about raw power right now. A cabinet saw is not in my near future, space or money wise…
colo/SFA: I only have the original bosch blade ATM, and it’s a 40-count. Are ripping blades generally not going to give me a glue ready finish? Or is this mainly the difference between the cheap and the not-so-cheap blades, such that buying a freud ripping blade might make sense?
The ripping that I’m doing is to SPF 2-by’s which will be glued up and used in a platform bed frame… it’s not clear whether it’s worth buying a rip blade just for this, but I thought it was worth asking the question. At a minimum, I will buy at least one good combination blade by the end of this week.
Also, I have read that thin kerf blades are better for contractor saws (due to the power issues)... What are the disadvantages to thin kerf?
View Thos. Angle's profile
Thos. Angle
3236 posts in 449 days
348 days ago
I use a Freud Glueline Rip and switch to a Freud Melamine to rip sheet goods. It works real well. The Freud blades have worked pretty well for me and now work better since I switched to link belts on my Jet table saw. I ruined a couple blades because of stretched out belts. The burning and problems have now been eliminated. The link belts will help your contractor saw as well. I think my next set of blades will be Forrest. I want to see if twice the price is twice as good. Lee Jesberger swears by Forrest. Freud makes a rip blade that is not too expensive for ripping 2 by material.
View dalec's profile
dalec
458 posts in 375 days
348 days ago
Hi Ben,
I also have a Bosch 4000. Mine was purchased used and needed to go to the factory service center for work. I have it back and am in the process of researching saw blades. I have received several responses to my forum topic on full or thin kerf.
If my table saw had more hp, I would go for the full kerf. However from all I have read, I am coming to the conclusion that thin kerf would work best for me on the Bosch 4000, because of the thin kerf places less stress on the motor. I interpret this to mean the thin kerf increases the cutting power of the Bosch over a full kerf mounted blade. Not more torque, but more efficient use of that torque. I may be all wet on this. Correct me if I am off on this.
Freud, Forrest and Ridge from all my reading are very good to excellent.
Best of luck on your decision.
Dalec
coloradoclimber
348 days ago
Ben,
In general yes, a ripping blade, lower tooth count, is going to give a rougher surface than a higher tooth count blade. The exception to this is when you overfeed a higher tooth count blade and end up with chatter or burning.
As for being glue ready it depends on your definition of glue ready. If you want a rub ready gluing surface my experience is that the Forrest WWII ripping 5/4 hardwood will give a rub ready face, smooth as a babies butt. I tend to use the forrest more than the freud so I don’t have a real strong opinion of freud other than to say that every time I’ve used the freud blades I’ve been happy. No negative thoughts on my part generally means it’s a pretty good blade. My opinion is that either blade, freud or forrest, sharp and clean, will give a face that is ready for glue up.
My junk blades no longer, probably never did, produce what I consider a glue ready face.
I’m an advocate for matching the blade to the job. That means a stack of blades and swapping them as needed. There is a different view that says that’s what combination blade are for, one blade to do all things.
As for thin vs thick kerf blades I’ve been using mostly thin kerf blades these days, in a 3 hp cabinet saw, and I’ve been happy. I know there is a group that says thin kerf is a gimmick, that you should only use standard kerf. I’ve not had any problems with thin kerf so far. I’m more of a mind, why use a chain saw if you can get the results you want with a scalpel.
View ben's profile
ben
347 days ago
Thanks for all the info. I went ahead and bought 2 thin kerf freuds—the 24 tooth rip blade, and the 50 tooth combination, and will be putting the freud plywood and forrest WWII on my list as my next blades. Also will be cleaning the bosch blade with some simple green and light elbow grease, to see how that improves cutting (suggested from another thread). Thanks!
View edp's profile
edp
101 posts in 447 days
347 days ago
I had been using the Oldham “Signature blades. 16” on the beam saw and 10” on the table saw and really liked their performance, especially at the cost. After hearing so much hoopla over the Forrest WWII, I got on for the table saw. I have to say that I don’t see any difference in performance.
Ed
-- Come on in, the beer is cold and the wood is dry. www.crookedlittletree.com
View edp's profile
edp
347 days ago
Hey Ben, that burning you are referring to may not be associated with the blade at all. I’d more likely suspect a misalignment of the fence to the blade. I’m sure that there are several schools of thought on this, but on my saw, the fence is set a little wider on the back side of the blade than the front side. This guarantees that when you are ripping, the material between the blade and the fence will not rub against the back side of the blade, causing…..............you guessed it…............burning. Try adjusting your fence and see if that doesn’t correct your problem.
Ed
View ben's profile
ben
347 days ago
edp: I read about the fence issue as well, and plan to check my alignment shortly. I also just finished cleaning my existing blade, so hopefully these 2 might take care of things.
ebanista: thanks for the heads up. I ordered via the LJ/amazon store, so I appear to have gotten lucky, and bought the industrial blades.
Bookmark And Share This Page
