Cutting down counter height table and chairs
Forum topic by LaurenC posted 12-30-2009 11:14 PM 16191 views 0 times favorited 6 replies Add to Favorites Watch
View LaurenC's profile
LaurenC
2 posts in 3037 days
12-30-2009 11:14 PM
Topic tags/keywords: question counter height table legs
I’m buying this table
http://www.easylifefurniture.com/diningroom_Detail.asp?pSKU=2920
Which I like a lot, but my ceilings are low and the height might make my ceilings look even lower. If I decide in the future that I would rather have standard table height, what would cutting down the table legs and chairs entail? Hiring a carpenter? How much $? Or is it not worth the effort?
Thanks!
Lauren
View David Knapke's profile
David Knapke
2 posts in 3146 days
#1 posted 12-30-2009 11:40 PM
Well if you are at all handy, it is pretty easy to do. I just did this for a customer who got some stools passed down from his parents. He wanted them to fit in a cubby under his granite counter but they were bar height stools.
Here is what I did:
- I made a very small box the amount he wanted cut off (5” in this case) – 1/4
- I taped around the legs using green masking tape, makes it easy to mark and helps prevent splintering when cutting
- used a small 1/4” piece of plywood to ride on top of the box to mark around the legs
- Oh, the stools where standing up on my dead flat work bench, so I was marking up from the bottom if it was not obvious.
- What you cut with depends on what toys/tools you have. I was going to use a find hand saw but the legs were very hard so I gave up on that quickly. I put a fine metal cutting blade (to prevent tear out/splintering) into my sawzall after having clamped the stool upside down. Probably the best tool would have been a Fein Multitool but I was not going to shell out the cash for that.
- It took patience to get a straight cut, you are likely to get a little tear out unless you are REALLY careful so cut from the show outside corner to the hidden outside corner.
- I did a little tuning up with 100 grit sanding block and ‘touched up’ with a furniture marker.
From their perspective, it looks like the stools were intended to be that size from the outset.
-- djk
LaurenC
#2 posted 12-30-2009 11:54 PM
Thanks! So it sounds like it’s not too hard. It also sounds like I’m not crazy for buying a table and chairs that I might cut down. Be on the look-out for a forum post in the future asking how I can find someone to do this for me in West Los Angeles. Thanks!
View home4allseasons's profile
home4allseasons
2 posts in 1906 days
#3 posted 02-03-2013 08:30 PM
I actually just did this the other evening and posted the method I used here with pics of how I set up my clamps and saw guides. http://homemaker4allseasons.blogspot.com/2013/02/shorten-counter-top-height-table-with.html
All in all, the project turned out great and I am very happy that I was able to keep my table and now it is a little bit safer for my small children. My table legs were tapered and I don’t have the tools to measure the angles I would need to set the bevel and angle on the miter box. I was planning on using that originally but ended up using the good ol’ hand saw and some C-clamps and it worked out wonderfully. I was also even able to salvege the little plastic buttons off the ends of the original legs and hammer them back into the new ends of my table legs.
runswithscissors
2725 posts in 1993 days
#4 posted 02-04-2013 04:02 AM
I took a stool sample in to my doctor. Imagine how surprised we each were when we realized what the other was talking about.
home4allseasons
#5 posted 08-06-2017 05:22 AM
I posted my tutorial of how I cut down my own counter height table on my blog. The above link is outdated and you can find the tutorial here at garden full of dreams
View AlaskaGuy's profile
AlaskaGuy
4050 posts in 2277 days
#6 posted 08-06-2017 06:43 AM
I m buying this table
Thanks!
Lauren
- LaurenC
You link doesn’t work
