fix to fill
Forum topic by Partridge posted 1235 days ago 1222 views 0 times favorited 16 replies Add to Favorites Watch
View Partridge's profile
Partridge
296 posts in 2122 days
1235 days ago
Topic tags/keywords: trick tip
Any ideas on how to fill gaps and make it look good. all ready glue. It is a drawer side.
i was thinking black epoxy
side
side2
-- I get out in the shop when I can
16 replies so far
View webwood's profile
webwood
616 posts in 1416 days
#1 posted 1235 days ago
i take sawdust from the project (i have cups for each type of wood) mixed with glue , and fill the gaps – sand flush after dry -
-- -erik & christy-
View Andrew's profile
Andrew
709 posts in 1364 days
#2 posted 1235 days ago
What is that? Oak on Maple? I do what is decsribed above, your tagline is funny.
-- Even a broken clock is right twice a day, unless, it moves at half speed like ....-As the Saw Turns
12048 posts in 1507 days
#3 posted 1235 days ago
webwood’s idea is the best match ,
and the easiest .
black epoxy ,
will make it look like it already does !
and the black tint will get into the grain .
View SnowyRiver's profile
SnowyRiver
45610 posts in 1646 days
#4 posted 1235 days ago
I agree with webwood too. I usually mix fine sawdust from the wood I have used with poly glue fill the gaps and sand it.
-- Wayne - Plymouth MN
View bayspt's profile
bayspt
292 posts in 1870 days
#5 posted 1235 days ago
I agree with the dust. Mix with glue till a paste. I tend to smear a little even in tight fitting joints. I too found your tag line funny. Oh the little ironies in life. If I spent as much time working as fixing my mistakes, I would produce twice as much. Of course I wouldn’t learn a whole lot.
-- Jimmy, Oklahoma "It's a dog-eat-dog world, and I'm wearing milkbone underwear!"
View PurpLev's profile
PurpLev
7729 posts in 1814 days
#6 posted 1235 days ago
I have to go against sawdust mix – it still will look like a fix, since the sawdust mix doesnt have grain.
instead of trying to fix the maple side – I recommend trying to fill the oak front.
here is how I did it and you really can’t tell it was fixed now.
Partridge
#7 posted 1235 days ago
thankyou or the ideas.
Todd A. Clippinger
8654 posts in 2265 days
#8 posted 1235 days ago
I had to chuckle as I read your signature line:)
Anyway, the epoxy and sawdust fix is a common one that I use.
PurpLev brings up a valid point. The epoxy and sawdust mix does not have grain but it does a pretty good job overall and with the size of gap may exceed the limits of what may be offered to hid the error with this solution.
You could certainly try PurpLev’s solution of inserting slivers of like wood into the gaps.
You might try both fixes to see how they work out and that way you will have a good first-hand experience with both of these methods.
Black colored epoxy would not be a good idea.
Good Luck!
Partridge
#9 posted 1235 days ago
Todd,
This allso made me chuckle went i realized what i wrote. I am going to change this.
as for the fix i decided to go with slivers. I am going to fume this project. my thinking is sense the fix is wood that it will act like wood good or bad.
but i am going to try saw dust and epoxy. when the need arises.
Here is the fix.
1
2
3
I will post finshed door to see if my theory is right.
#10 posted 1235 days ago
much gooder !
i also do both sometimes .
View Rog's profile
Rog
59 posts in 1924 days
#11 posted 1235 days ago
Ok little brother that is much better. 99% better kinda like. Do it right the first time. Becuase fixing it is a wast of time. I’m surprised that no one ever caught that. LOL you always put a smile on my face…....
-- I get out to the shop when Ryan lets me. Arggggggggggg
View nmkidd's profile
nmkidd
758 posts in 1338 days
#12 posted 1234 days ago
I’ve tried numerous off-the-shelf so called wood fillers …...resulting in a crappy looking fill
My choice is the saw dust and glue method
-- Doug, New Mexico.......the only stupid question is one that is never asked!........don't fix it, if it ain't broke!
Partridge
#13 posted 1234 days ago
ok the magority of you go with saw dust in glue, OK. Her is what I want to know is this a fix that will sain, or change with wood coloring… glue left on wood when finish (ie stained, oiled, clear coat, et.) will show up yellow. this fix to me would be better suited for painted work or gap filling were thing are not going to be seen.
Epoxy and saw dust seems like a good filler if you tinted it to the ending finish color.
It is good to have choices and there is not one fix that will work in all situations.
Todd A. Clippinger
#14 posted 1228 days ago
I just came back to see the results. I should have stopped back sooner.
One thing to keep in mind is that with both the glue or epoxy and sawdust (I also use super glue and sawdust) the glue line will typically be darker than the surrounding area. Once any stain is added it tends to blend fairly well.
Looking at your repair I think that the corrective action would be a combination of slivers followed by glue and sawdust combo.
I am sure that you just learned more by experience than any book or anybody could tell you about.
View bsherman's profile
bsherman
76 posts in 1693 days
#15 posted 1223 days ago
Well cool. I’m glad I’m not the only one who has done the “slivers” thing. It looks great.
-- Brian
