Used Wagner CS9000
Forum topic by tblake1984 posted 11-23-2015 09:37 PM 1638 views 0 times favorited 3 replies Add to Favorites Watch
View tblake1984's profile
tblake1984
29 posts in 1407 days
11-23-2015 09:37 PM
I have been saving up for an earlex 5500 but the air supply and gun interface bothers me. I wish it used a standard connection like the Fuji systems.
Anyways, I found a used Wagner CS9000 on Craigslist (http://providence.craigslist.org/for/5325360277.html) and just wondering if anyone has ever bought one of these and cleaned it up. I understand that CapSpray is a highly respected name in HVLP and parts seem to be available for this system.
What do you think?
3 replies so far
tblake1984
#1 posted 11-24-2015 06:22 PM
No responses yet? Has anyone ever bought a used CapSpray set? Just wondering how they hold up or if I should worry about replacing the turbine at some point… my impression is that CapSpray is a highly regarded brand.
View dhazelton's profile
dhazelton
2805 posts in 2532 days
#2 posted 11-24-2015 06:42 PM
Google doesn’t give anything up on it. If it runs and sprays and the gun and tips look clean then go for it. A turbine is just a shop vac motor essentially (Fine Woodworking had plans to build your own about 20 years ago). That looks like it may have been used in a cabinet shop and if you need that kind of duty cycle then try it. You can always resell it and not be out much. There’s a few on eBay and they are asking a lot more than $150.
tblake1984
#3 posted 11-24-2015 07:02 PM
Thanks dhazelton. Yeah, Google wasn’t very helpful to me either though the fine folks at Capspray were and they responded quickly to my request for an owner’s manual. They also stated that any replacement parts I might need are still available.
I wish I could post the owner’s manual as it might be helpful to someone in the future but basically, the specs look pretty good. 7.5psi, 1650 watts on the turbine and the gun looks like a pretty close predecessor to CapSpray’s current Maxum II. Only real difference I could see is that the air flow adjustment is on the side.
