Looking for a solution for a sliding/rotating drawer.
Forum topic by lateralus819 posted 11-23-2015 01:36 AM 741 views 0 times favorited 9 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 1793 days
11-23-2015 01:36 AM
I’m designing a cabinet in sketchup and I’m looking for something that I can mount to a tall drawer to let it slide out of the cabinet and also spin.
It’s a tall drawer to hold necklaces and i figure it would be easier if it could slide out of the cabinet and then spin to make it easier to access the necklaces.
I tried to figure some easy way out so I could make the drawer the full height and not lose room from a slide or something. Maybe I am over thinking it.
9 replies so far
View UpstateNYdude's profile
UpstateNYdude
912 posts in 1887 days
#1 posted 11-23-2015 01:38 AM
Why not do normal dadoed in slides and then a lazy susan type bearing so it can spin.
-- Nick, “I am always doing what I cannot do yet, in order to learn how to do it.” – Vincent Van Gogh
lateralus819
#2 posted 11-23-2015 02:08 AM
I had thought about that, but would like it to be hidden for the most part (concerning the case work).
I swear I saw something similar on a jewelry box.
View Daruc's profile
Daruc
460 posts in 1036 days
#3 posted 11-23-2015 02:23 AM
Maybe you could use some flipper door hardware. May have to do some engineering.
View grass's profile
grass
4 posts in 868 days
#4 posted 11-23-2015 03:21 AM
I built 2 free standing jewelry chests with 29” tall pocket pull out necklace drawers on either side. I used pocket door slides and 90 degree column hinges. I preferred the drawers open about 60-70 degrees. I did this by doing a slight 45 degree camber on the drawer bottom[hinge side] and used a 6 mm BB plywood spacer between the drawer side and slide carrier board when mounting the hinges. You get full drawer height but not full depth . I used 14” slides and my drawers were 10 1/2” wide.
View David Taylor's profile
David Taylor
326 posts in 991 days
#5 posted 11-23-2015 04:46 AM
grass, when you say pocket door slides, you mean like these? http://www.rockler.com/ez-pocket-door-system-pocket-door-slide
These are what I thought of at first to suggest adapting, but couldn’t remember what they were called. If that’s what you mean, thanks for helping me learn the terminology!
-- Learn Relentlessly
View TheFridge's profile
TheFridge
8862 posts in 1390 days
#6 posted 11-23-2015 05:12 AM
Bottom drawer slide with a lazy Susan deal mounted below the bottom. With a circular cutout in the bottom?
grass
4 posts in 868 days
#7 posted 11-24-2015 03:02 AM
Yes. My slides from Lee Valley and hinges from Custom Service Hardware. The hinges are designed for the narrow flip door on pocket doors.
View bondogaposis's profile
bondogaposis
4597 posts in 2255 days
#8 posted 11-24-2015 03:23 AM
Make a double frame. The outer frame slides out the inner frame pivots on center pins.
-- Bondo Gaposis
woodbutcherbynight
3942 posts in 2313 days
#9 posted 11-24-2015 05:00 AM
- bondogaposis
Sounds good, may use that myself on a upcoming project.
