Need to find a knurled tapped thumbwheel to make anti-rack device for vise?
« back to Hand Tools forum
Forum topic by ElChe posted 11-22-2015 05:46 AM 1959 views 0 times favorited 21 replies Add to Favorites Watch
View ElChe's profile
ElChe
630 posts in 1330 days
11-22-2015 05:46 AM
Topic tags/keywords: vise anti-racking thumbwheel question bench
The Diefenbach benches came with a nifty thumbwheel on each vise that resided in a forstnered hole on the vise. You could then spin it tight against the bench to prevent racking. I can’t find a big enough thumbwheel for this purpose. I’m thinking knurled thumbwheel 2” outer diameter and tapped for 1/4” or 5/8” all thread? I can’t find a picture of the device on Google but I saw it in one of the workbench books. I currently use a shopmade one similar to the one Lee Valley sells. I’d like to have the anti-racking function integrated into my bench vises. Any ideas? My Google fu has failed me and local machinists won’t touch the project. Thx!
21 replies so far
View JoeinGa's profile
JoeinGa
7736 posts in 2001 days
#1 posted 11-22-2015 06:31 PM
Are you talking something like this? I may have a couple if you can use ‘em
View DrTebi's profile
DrTebi
265 posts in 3260 days
#2 posted 11-22-2015 07:11 PM
McMaster has a great selection of knobs, try their site here:
http://www.mcmaster.com/#machine-component-knobs/=zx9ksd
I have bought a few there already, and they were all great. I especially like the “Steel Four-Arm Knob” style and the “Comfort-Grip Polypropylene 4-Arm Knob”.
Not sure if they have 2” ones though, that seems quite large for a 1/4”-20 knob.
View bondogaposis's profile (online now)
bondogaposis
4718 posts in 2345 days
#3 posted 11-22-2015 07:49 PM
ElChe
#4 posted 11-22-2015 08:09 PM
It would be something like this but bigger.
A threaded rod is attached to the vise on one end and the rod passes through a hole the bench as you open or close the vise. When you have a board in the other end of the vise, To prevent racking you spin the thumb wheel on the rod on the other side of the vise until it contacts the bench. The thumb wheel prevents the side without the board from racking. Am I making any sense? Oh wait, I do have a picture! This is the diefenbach anti-racking device:
ElChe
#5 posted 11-22-2015 08:20 PM
Here it is.
View MrUnix's profile
MrUnix
6698 posts in 2193 days
#6 posted 11-22-2015 08:24 PM
Get a piece of 1/4” aluminium, cut into a circle, drill and tap. You can go as fancy or as simple as you want.
View Kazooman's profile
Kazooman
1005 posts in 1946 days
#7 posted 11-22-2015 08:31 PM
Geez…. I was so proud to have found the picture and was about to post it but ElChe beat me to the punch. Well done!
I agree with Brad, you should be able to make one of these yourself. Post a picture when you are done.
View bigblockyeti's profile
bigblockyeti
5111 posts in 1714 days
#8 posted 11-22-2015 09:12 PM
Wouldn’t the guide rods of a quality vice alone prevent this? Mine are 1.5” diameter and about 12” apart and I’ve never had this problem.
ElChe
#9 posted 11-22-2015 09:18 PM
My vise racks despite being fairlynrobust. Hmm. I’m wondering if I could cut aluminum or steel flat stock with a bimetal holesaw on my drill press then tap the disc? Then how to do the knurling. I’m gonna give it a try m
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1170 days
#10 posted 11-22-2015 09:35 PM
After you cut the aluminum round and tapped the hole in it you could ask a local turner if they would knurl it with a knurling texturing tool.
Kazooman
#11 posted 11-22-2015 09:54 PM
The threads in 1/4” aluminum might not be very robust. You could use a good diameter all thread rod and a steel nut. The nut could be epoxied to anything for the wheel. The nut would be taking the force from the vise, not the disc.
How is the rod attached to the front jaw of the vise? Can it be easily removed? If not it would limit the use of that end of the jaws.
MrUnix
#12 posted 11-22-2015 10:10 PM
I don’t believe that would be much of a problem… there wont be a lot of force on them as it’s just there to keep the free side of the vice from being pushed back. As for the knurl, the ones pictured are not knurled… the score marks on the outer edge could easily be made using a metal file, dremel tool with a cut off wheel, hack saw, etc…
View oltexasboy1's profile
oltexasboy1
250 posts in 1698 days
#13 posted 11-22-2015 10:24 PM
You can find a local machine shop that uses round bar stock and have them cut a piece the size and thickness you need and thread it yourself.
-- "The pursuit of perfection often yields excellence"
DrTebi
#14 posted 11-23-2015 04:15 AM
“The Bay” often has what you thought you could not find anywhere else…
http://www.ebay.com/sch/Metals-Alloys-/29402/i.html?_from=R40&_nkw=aluminum+disc
Buying a disc of the right size and drilling and tapping it, is what I would do. Unless you want perfection, you could also knurl the edges yourself with a file and a bit of geometry…
View Andre's profile
Andre
1827 posts in 1800 days
#15 posted 11-23-2015 07:16 AM
Check Kiefers projects,I believe he made one for his Bench, think it was of the quick release type. Might have go take another look at it?
Found this link
http://lumberjocks.com/projects/98847
