I need some feedback please!
Forum topic by Jim posted 12-29-2009 03:54 PM 886 views 0 times favorited 2 replies Add to Favorites Watch
View Jim's profile
Jim
150 posts in 3230 days
12-29-2009 03:54 PM
Topic tags/keywords: bird feeder joinery removable
Ok, the mother-in law has requested a project from me, but I need some help designing it. She wants a cardinal bird feeder. I guess cardinals prefer a flat tray to feed from rather than your usual feeders. She wants to put it under her other feeders which are on a double shephards hook.
My ideas on this: I was going to cut 6 or 8 wedges to make the platform into a hexagon or octagon shape, then putting a 1/2 inch rail along the outside for a perch and to keep seed from spilling off. The issue I have is thinking of a way to make it split in two to get it onto the pole, and also making it removable for bad weather. It will suspend on chains from the top of the pole, but needs a removable but study platform. Sorry I cant draw a picture (Im at work and no scanner) but I hope my description give the jist of the idea.
Any ideas/input it much appreciated!
-- -- Jim - Kokomo, Indiana
2 replies so far
View lew's profile
lew
11945 posts in 3663 days
#1 posted 12-29-2009 04:50 PM
Perhaps a large diameter split dowel with a hole- lengthwise- slightly larger then the diameter of the shephards hook staff. Make the feeder in two halves. The split dowel could be fastened to the bottom of the platform- one half of the dowel on each half of the platform- the platform “reassembled” around the staff using something like a worm gear hose clamp to hold the dowel halves/feeder halves together.
View Jim's profile
Jim
#2 posted 12-29-2009 07:22 PM
wow… So simple yet ingenious! Thank you so much, I knew I could could on fellow LJs to help. Thanks again!
