Seeking Design Advice on Creating Joint
« back to Joinery forum
Forum topic by Bernspen posted 11-22-2015 04:06 AM 842 views 0 times favorited 12 replies Add to Favorites Watch
View Bernspen's profile
Bernspen
30 posts in 1186 days
11-22-2015 04:06 AM
Topic tags/keywords: joining
This is an E table. My daughter Emily asked me to make her one. I said sure, ‘cause it looks easy, then I started thinking about jointing. Oops.
I’ve got some nice 2 inch mahogany I can use. I thought mortise and tenon, but that bottom joint needs to support the table, and the top shelfneeds to support whatever, So I’m thinking, is a mortise/tenon the best I can do? Mortise and Tenon dowled? I considered just a butt joint, and using lag bolts hidden under plugs. Then I thought about a sliding dovetail, but I think now I’m going to cut some large dovetails, just two or three, drill both the tails and the pins, stick a big lag bolt in the hole, and plug it.
But I’d like your folks thoughts, please.
-- We have met the enemy, and he is us.
12 replies so far
View Gixxerjoe04's profile
Gixxerjoe04
850 posts in 1485 days
#1 posted 11-22-2015 04:49 AM
I’d say the lag bolts with plugs would be the easiest, unless you have the domino. Of course I don’t see why a big m&t won’t work.
View Aj2's profile
Aj2
1273 posts in 1706 days
#2 posted 11-22-2015 04:58 AM
I’d cut about a third of the vertical upright piece off and set it aside.Then lag bolt or some very aggressive wood screws into the three horizontal pieces.Then glue back on the cut off.
I wouldn’t spend very much effort like Dts or tenons.I just don’t consider it to be furniture.Its just a thing.
No disrespect toward you or yours.
-- Aj
View jumbojack's profile
jumbojack
1673 posts in 2532 days
#3 posted 11-22-2015 05:23 AM
I like the dovetail idea.
View ElChe's profile
ElChe
630 posts in 1244 days
#4 posted 11-22-2015 05:53 AM
It would be much easier as an “M” table. :) pinned through dovetails would work on top and bottom. Box style joint for middle shelf or a hefty mortise?
View TheFridge's profile
TheFridge
8902 posts in 1394 days
#5 posted 11-22-2015 06:10 AM
I think box joints would be the strongest if you could manage.
View Ocelot's profile
Ocelot
1887 posts in 2546 days
#6 posted 11-22-2015 06:22 AM
There are good reasons why cantilever designs are rarely seen – especially in wood. Due to wood movement, almost any kind of joint in a structure like that will become loose and saggy in dry weather.
View oldnovice's profile
oldnovice
6554 posts in 3276 days
#7 posted 11-22-2015 06:27 AM
You unroll and flatten the paper then … oops wrong kind of joint.
I agree with TheFridge if you have the room.
You could also reduce the center member of the E to reduce some of the leverage on that surface.
Just don’t let her sit on it like my grandson does on my keyboard shelf in my computer armoire.
View jerryminer's profile
jerryminer
890 posts in 1349 days
#8 posted 11-22-2015 07:05 AM
It might be “cheating”, but I’d be tempted to rip a little off each edge, and let in some metal “L” and “T” brackets, then cover with the ripped strips.
oldnovice
#9 posted 11-22-2015 07:27 AM
If you do what jerryminer suggest, you might as well go all the way to embedding standard shelf standards and supports like those available from Knapp & Vogt and others as these can hold a lot of weight and, with a little planing, the middle of the E could be vertically adjustable.
A little more of a challenge!
View AlaskaGuy's profile
AlaskaGuy
3913 posts in 2217 days
#10 posted 11-22-2015 08:49 AM
If you bought it at Walmart for 269 dollars you get box joint top and bottom and through M&T in the middle.
http://www.walmart.com/ip/27797681?wmlspartner=wlpa&adid=22222222227018950693&wl0=&wl1=g&wl2=c&wl3=52581882495&wl4=&wl5=pla&wl6=79654006575&veh=sem
View mahdee's profile
mahdee
3844 posts in 1675 days
#11 posted 11-22-2015 12:07 PM
Looking at the back it looks like top and bottom are like finger joints and middle is mortise and tenon.
-- earthartandfoods.com
View Tennessee's profile
Tennessee
2752 posts in 2422 days
#12 posted 11-22-2015 12:37 PM
Looking at the picture in the original post by Bernspen, you can see a bit of the edge at the top on what looks like a flat board glued on the large flat surface that could be covering anything.
If so, I’d bet that there is nothing more than long horizontal lag bolts under that board holding butt joints. Same idea as Jerry, but a lot simpler. Or maybe M&T, but my guess is if it is a production piece, bolts.
