edge gluing boards
Forum topic by RickB posted 12-28-2009 06:54 PM 4870 views 0 times favorited 6 replies Add to Favorites Watch
View RickB's profile
RickB
48 posts in 3380 days
12-28-2009 06:54 PM
Topic tags/keywords: gluing
All:
The short version is: My edge glued boards are bowed. Suggestions?
The long version:
Been trying to make an end grain cutting board. As I am gluing up the strips, I am seeing that there is a pronounced warp to the end product. While I was waiting for that glue to dry, I buzzed down a couple of strips of cherry which I glued together to make a plaque for an antler mount. This was just four strips of wood. These have a slight bow as well.
However, not everything I edge glue turns out this way. I made a seat for a stool some time ago. This was edge glued oak. It is nice and flat. Some of the pieces of the cutting board are cupped, other pieces are flat.
I checked my jointer and it is cutting flat. I did not double check the table saw, but I think it is fine.
The jointer is leaving a very slight ridge on the material… I do need to get that taken care of.
Any thoughts? One thought I have is that I am squeezing the parts together too tight, and causing a bow sometimes.
Thanks
Rick
View TheDane's profile
TheDane
5575 posts in 3903 days
#1 posted 12-28-2009 07:22 PM
You could be putting to much pressure on, but there are a couple of other things to check.
Are you clamping from both sides of the board? If all of you clamps are under the glue-up, that could contribute to the problem. I alternate clamps on top and under the glue-up and try to keep even pressure on all.
Also, boards have a tendency to cup towards what would have been the center of the tree. Take a look at the end-grain and check the direction of the growth rings. If they are all going the same direction, there is a pretty high probability they will cup on you. To counteract this, flip every other board so the growth rings are face down.
View Don Newton's profile
Don Newton
716 posts in 3858 days
#2 posted 12-28-2009 07:52 PM
Yeah….what TheDane said! Check your glue-up with a straight edge as you clamp it. Don’t overtighten.
-- Don, Pittsburgh
View dkg's profile
dkg
30 posts in 3325 days
#3 posted 12-28-2009 07:54 PM
Try using cauls across the boards until the glue sets (overnight for titebond). I have been gluiing up Spanish Cedar for cabinet cases. The boards are random width and 8’ long. The panels are 24-34” wide and I use 3 sets of 2×4 on edge spaced about 3’ from the other. The 2×4 are clamped together.
RickB
#4 posted 12-28-2009 07:59 PM
Thanks y’all. A quick followup question: Most of my clamps are simple bar clamps… hard to explain… What my clamps are NOT is parallel jaw clamps. Would a parallel jaw clamp help me or no?
27250 posts in 4062 days
#5 posted 12-28-2009 08:46 PM
Parallel clamps will enable you to spread the clamping pressure over a larger area and provide a more even clamping pressure. But the downside is that they are more expensive. Using cauls will help you in your situation but you might want to try the K-body clamps and see if they fit your situation. I tend to use only Bessey clamps. I do have a few 8’ bar clamps but use them only when I need a long clamp.
TheDane
#6 posted 12-28-2009 09:03 PM
Scott is right … it isn’t necessarily so much the type of clamp as it is the number of clamps you use and the pressure you put on them. I have a set of 6 K-body clamps that I often supplement with pipe clamps.
When I use cauls, I use 2×2 scraps wrapped in plastic with a pair of C-clamps on each one. I actually taper the cauls a bit so the center is a skosh higher than the ends, and put a caul on both sides of the glue-up.
