Joining cutting boards
« back to Joinery forum
Forum topic by Autorotate posted 11-21-2015 04:04 AM 774 views 0 times favorited 5 replies Add to Favorites Watch
View Autorotate's profile
Autorotate
37 posts in 796 days
11-21-2015 04:04 AM
Topic tags/keywords: cutting board joinery wood planer
Hello,
I am looking to go another round in making a black walnut end grain cutting board. I am looking for advice on how to join (2) 12 inch boards together once I am done.
I know it’s an odd size, but I want a cutting board 24”W x 36”L and need to do it in (2) separate 12 inch wide sections so it will fit through my 13 inch planer. Is it safe to just glue and clamp the ends together that would have normally been glued together at the end after the planing?
Or is it better to plane the wood strips originally and not plane once it is put together? I’d just have to sand away then. I like planing once everything is together, but I end up with (2) 12”W pieces that need to join.
Any suggestions? Thanks!!
5 replies so far
View joey502's profile
joey502
519 posts in 1394 days
#1 posted 11-21-2015 05:35 AM
Running end grain through a thickness planer is asking for trouble, it can easily damage the work piece and the machine.
I am not following the order in which you would like to glue the parts. Do you have a picture of how the parts will be laid out and glued?
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1052 days
#2 posted 11-21-2015 07:12 PM
Welcome to LumberJocks.
As Joey502 said it is not wise to run end grain through a planer. Instead many will use a drum sander.
As for alignment of different pieces I use this to keep everything aligned. Other companies make similar products. If you use wood for the cauls be sure to wax them or apply a finish to them so that glue squeeze out does not glue the caul to your cutting board.
Autorotate
#3 posted 11-21-2015 08:15 PM
Thank you very much for the replies. I am sorry if there was confusion.
My planer is only 12 inches and I waned to make a 24 inch board. So what I did was make two exact same boards at 12 inches a piece so they would fit through the planer originally. They have all been jointed, planed, glued, and cut into their respective strips. They were then cut again and as you know flipped end grain up and glue again. Each board being 12” wide.
I know not to run through the planer again and in hindsight (found a local mill with 24” drum sander) I would have made the whole board one piece. But now I have two 12” wide blocks ready for final glue, sand, and routing.
Hope that cleared it up a little.
View CueballRosendaul's profile
CueballRosendaul
484 posts in 2016 days
#4 posted 11-22-2015 04:03 AM
I think I would use some big fat dowels for strength and as alignment pins. Clean up the squeeze out after an hour while it’s still gooey, then if you played your cards right, you’ll only have to hit the joint with a card scraper and final sanding.
-- Matt CueBall Rosendaul. I don't think I've ever had a cup of coffee that didn't have cat hair or sawdust in it.
View Gixxerjoe04's profile
Gixxerjoe04
850 posts in 1452 days
#5 posted 11-22-2015 04:51 AM
Could glue them together and make a router sled to flatten it out.
