table tops
Forum topic by slabdog posted 11-21-2015 04:03 AM 537 views 1 time favorited 3 replies Add to Favorites Watch
View slabdog's profile
slabdog
1 post in 795 days
11-21-2015 04:03 AM
anybody having the same issue I have with getting a super smooth finish. I got 2 coats of sanding sealer and three coats polycrylic on a table. always somehow I still get those little specs of what appears to be dust particles landing on the wet surface. Just a few but enough to notice. Can these be buffed out? what would be the procedure?
3 replies so far
View Rick_M's profile
Rick_M
10843 posts in 2255 days
#1 posted 11-21-2015 04:25 AM
Sand between coats and sand the final coat until smooth. Basically you need to polish by sanding with successive grits and buff if you want. Sometimes people will wipe on a thinned coat for the final if they want a shine.
-- http://thewoodknack.blogspot.com/
View BurlyBob's profile
BurlyBob
5151 posts in 2141 days
#2 posted 11-21-2015 04:44 AM
I use wet/dry sand paper 220 for the first coat of polyurethane. Then I move to 600 for the next several coats. I also try to make sure to reduce air borne dust to the minimum. Sometimes I will use a tack cloth to wipe any residue off the surface. Then for the last several coats I use a piece of polyester cloth folded in a rectangle wrapped in a piece of panty hose. These don’t leave any lint. I thin the poly to almost water and using the cloth I can move the poly like a squeegee and by playing the light I can get a very nice smooth finish. the most I’ve ever done is 12 coats. It’s like glass.
View AlaskaGuy's profile
AlaskaGuy
3797 posts in 2184 days
#3 posted 11-21-2015 07:24 AM
“Let the waterborne fully cure for a couple of weeks. You can then “rub it out” just like any finish. Use mineral oil, mineral spirits or water as your lubricant”.
The above advice was stolen from Howard Acheson, a well known and respected person in the woodworking circles. He knows his stuff.
https://www.youtube.com/watch?v=zN-9vCSJWDQ
