Are we breathing toxic woodsmoke?
Forum topic by sophiasieber posted 11-21-2015 04:01 AM 1326 views 1 time favorited 22 replies Add to Favorites Watch
View sophiasieber's profile
sophiasieber
1 post in 880 days
11-21-2015 04:01 AM
Topic tags/keywords: question woodburning
My father in-law has been bringing in truckloads of scraps that he got free from the lumber yard, to burn in the fireplace. I looked at the stack the other day and noticed they all had the tiny perforations that are visible in pressure treated lumber. My partner and I brought up the concern that we (and our two year old) are breathing toxic fumes when we visit and a fire is going in the living room. My father in-law seemed mildly insulted that we would suggest that, and brushed it off by insisting that the scraps were the end pieces cut off before the mill treated the wood. I am fairly certain that there would not be marks on it unless it were tainted. My questions is- does this wood look safe? Is it even possible for lumber to have these perforations before pressure treating?
I have to say we’ve been avoiding going there because of the exposure risk (and avoiding conflict). I would very much appreciate having these concerns put to rest!
Thanks, Sophia
22 replies so far
View Woodknack's profile
Woodknack
11469 posts in 2342 days
#1 posted 11-21-2015 04:26 AM
Contact the sawmill and ask.
runswithscissors
2724 posts in 1987 days
#2 posted 11-21-2015 05:16 AM
Don’t burn it. Ask your FIL not to bring any more.
View Knothead62's profile
Knothead62
2584 posts in 2923 days
#3 posted 11-21-2015 02:00 PM
Question: what else do you inhale in the course of a day? I agree though, contact the sawmill and ask.
View mahdee's profile
mahdee
3868 posts in 1729 days
#4 posted 11-21-2015 02:49 PM
Doesn’t look like treated wood. Treated wood coming out of the oven is usually soaking wet and greenish color.
-- earthartandfoods.com
View HarveyM's profile
HarveyM
106 posts in 1984 days
#5 posted 11-21-2015 03:02 PM
Sophia-
I’m inclined to trust the nose in this case. If you can’t smell wood smoke in their house, your risk is minute.
Your father-in-law is right that the perforations are made before the wood is treated
(http://pods.dasnr.okstate.edu/docushare/dsweb/Get/Document-2531/NREM-5047web%20color.pdf)
But I’m not sure if the offcuts are done before or after the treatment step, if they’re from a lumber yard (and not the manufacturer) I’d be suspicious.
-- Just a Duffer
View MarcusM's profile
MarcusM
57 posts in 2942 days
#6 posted 11-21-2015 04:52 PM
PT wood, once dimensioned for thickness and width, is then perforated to allow for deeper penetration of the treatment. The last thing done just prior to the teatment is to dimension it to length. If it wasn’t first cut to length you wouldn’t get the treatment penetration on the ends of the final product where it is most crucial to help prevent rot. I’d say those off-cuts are definitely from pre-treatment boards.
Regards, Mark
-- Tilbilly Mark
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1138 days
#7 posted 11-21-2015 05:04 PM
In a far far away century I watched my grandfather build a fireplace for his house. He told me that a properly designed fireplace should draw all of the smoke up the chimney and there should be no smell of smoke in the room.
I agree with HarveyM in if you can’t smell the smoke you should be ok. Also consider how long you are exposed. A couple of hour visit occasionally compared to living in the house.
View Hermit's profile
Hermit
186 posts in 1287 days
#8 posted 11-21-2015 05:26 PM
I would never burn pressure treated wood indoors (or outdoors) and there’s definitely PT wood in that photo. Here’s a little info.
http://www.arboristsite.com/community/threads/reasons-why-we-dont-burn-pressure-treated-wood.71229/
http://www.strongtie.com/productuse/ptwoodfaqs.html
-- I'm like the farmer's duck. If it don't rain, I'll walk.
Woodknack
#9 posted 11-21-2015 09:16 PM
... there s definitely PT wood in that photo.
- Hermit
Why do you believe that?
View clin's profile
clin
825 posts in 958 days
#10 posted 11-22-2015 12:34 AM
I agree with HarveyM in if you can t smell the smoke you should be ok. Also consider how long you are exposed. A couple of hour visit occasionally compared to living in the house.
- WoodNSawdust
In general I would agree. But some chemicals can be very toxic in small amounts. So just because you can’t smell smoke, doesn’t mean there isn’t something dangerous there. I have no idea how bad PT chemicals are, and perhaps they could even be harmless when burned.
This reminds my of the plastic coated wood bowling pins my dad used to burn in our fireplace 50 years ago. I can only image the nasty stuff that went up the chimney.
-- Clin
View bigblockyeti's profile (online now)
bigblockyeti
5085 posts in 1682 days
#11 posted 11-22-2015 01:21 AM
It’s probably fine.
View JohnStevens's profile
JohnStevens
22 posts in 2919 days
#12 posted 11-26-2015 08:05 AM
Great rule of thumb: Never ever ever burn PT wood. Depending on how old the wood is, it could have CCA (arsenic) in it which is toxic. Even the newer stuff is still nasty stuff. Even worse for children or older folks. If it is illegal to dispose of it in landfills, it certainly should not be burned!
From several air quality management district web sites “Treated wood should not be burned in stoves, fireplaces or outdoors because toxic chemicals are produced as part of the smoke and ash and can be harmful if inhaled. It is legal to dispose of treated wood in the landfill, although it’s always best to find a way to re-use it. Some of the chemicals that are commonly used as a wood preservative are Chromated Copper Arsenate (CCA), Ammoniacal Copper Arsenate (ACA), creosote and pentachlorophenol.”
-- "I'll show you my tenon if you show me your mortise!"
View rwe2156's profile
rwe2156
2880 posts in 1443 days
#13 posted 11-26-2015 11:39 AM
A. That doesn’t look like PT. You should believe what he says or check for markings before you “panic”.
B. The smoke should be going up the chimney not in your lungs.
C. That looks like pine, which is he really shouldn’t be burning in a fireplace anyway.
D. Chill – You’re over reacting. If you had any idea of the thousands of toxic substance you come into contact every day you wouldn’t believe it. Want to talk about molds?
No go home and check your AC filter ;-)
View Redoak49's profile
Redoak49
3188 posts in 1950 days
#14 posted 11-26-2015 12:21 PM
No way I would even take a chance exposing a 2 year old to the smoke. The smoke and ash are hazardous. Chill…no way. In addition, the smoke outside could contaminate your yard and surrounding area and people.
If it is pressure treated and he is burning it then the house is contaminated with toxic chemicals as some smoke escapes from a fireplace. A two year old put everything in there mouth.
Are you worried about insulting your father in law or protecting your child?
View dhazelton's profile
dhazelton
2746 posts in 2258 days
#15 posted 11-26-2015 02:18 PM
Most of that pile looks like cedar so I wouldn’t worry. But to all the folks who say ‘it’s okay to burn anything if you don’t smell the fumes’ I say burning P.T. is illegal, in my township anyway. Burning P.T. is really bad for the environment. Burying the stuff isn’t much better.
