Sharpening Forstner Bits
« back to Coffee Lounge forum
Forum topic by Jim Jakosh posted 12-28-2009 06:18 AM 7465 views 2 times favorited 6 replies Add to Favorites Watch
View Jim Jakosh's profile
Jim Jakosh
20488 posts in 3105 days
12-28-2009 06:18 AM
Does anyone have a slick way to sharpen Forstner bits? Like which way to you sharpen the flat area and what do you do to sharpen the teeth around the edge?
View KnotWright's profile
KnotWright
258 posts in 3487 days
#1 posted 12-28-2009 06:31 AM
I did a quick search online, here’s a few good examples for you:
http://www.wwch.org/TechData/Forstner_Bit_Speeds.jpg
http://www.youtube.com/watch?v=bt4weRZs0HM
There are a lot of other pages on this topic, but these two actually show two different methods of doing it.
I tend to use the first method, since it only requires a few tools.
-- James
View AJswoodshop's profile
AJswoodshop
1057 posts in 2276 days
#2 posted 09-14-2012 12:29 AM
Jim,
I have never sharpened my Forstner bits. But, I thought I heard my Grampa say that you could sharpen them on a drill doctor. Not sure thou, I love my forstner bits, I got them at a auction for only $9 dollars! It’s a 20 piece set!
AJ
View HorizontalMike's profile
HorizontalMike
7757 posts in 2914 days
#3 posted 09-14-2012 12:50 AM
Rat tail files come in handy here. Finer toothed, better “sized” for bit sharpening, and easier to control IMO. And I try to only minimally sharpen at any one time, in order to keep as much of the bit as I can. In this sense, I sharpen more frequently but less aggressively.
Jim Jakosh
#4 posted 09-14-2012 01:02 AM
Thanks, James for this info, that is what I thought. I have been sharpening the flat with a diamond hone and will now try to uses round stone on the curved area.
AJ, I have see a drill doctor and they tend to sharpen just the point of a drill and do a back cut to thin the point for less resistance when drilling without a pilot hole. I don’t thin they would address the surfaces of a forstner.
Hi Mike, they must not be too hard if a file will cut them. I’ll have to try that too. That U tube video was a good one but it showed a big one being sharpened. The ones that get dull the quickest are the 3/8, 1/2 and 3/4. I use them the most- especially the 3/4 one. I try a file to all the surfaces of the 3/4 one and see how it works!!
thanks, Jim
HorizontalMike
#5 posted 09-14-2012 09:43 PM
While I do not know, I do suspect that some of the cheaper Forstners are made with softer steel (I am NOT saying SOFT) than the highest quality bits. As a hobbiest, I just do not use them so much as to need to buy the best, though I understand that desire to have the latest/greatest at all times urge.
Jim Jakosh
#6 posted 09-14-2012 11:23 PM
Hi Mike. some say HSS but it may not be hardened High Speed Steel. that makes a big difference!!
