How do I re-square my blade?
Forum topic by McFly posted 11-19-2015 11:07 PM 656 views 0 times favorited 5 replies Add to Favorites Watch
View McFly's profile
McFly
273 posts in 1051 days
11-19-2015 11:07 PM
Topic tags/keywords: ras adjustment refurbishing miter saw question
The blade on my ‘59 Delta Rockwell RAS is listing between 1.5 & 3 counterclockwise when the stop engages.
The amount of list is small, so it’s not long before the motor drops right back into the stop and I go from a perfect right angle to a caddywampus 87. Not fun.
It seems like something is bent somewhere since the saw locks into the stop perfectly fine, but produces an angled cut when I’m set to a right angle.
What I need is a way I can adjust the saw to get my cuts square back to square. It seems I need to rotate my whole motor 3* clockwise and then adjust the dial’s indicator to accomodate
I don’t even know where to start on that.
5 replies so far
View MrUnix's profile
MrUnix
6766 posts in 2223 days
#1 posted 11-19-2015 11:13 PM
It would help if you tell us what model it is… probably a Super 900 or Super 990? Anyway, consult the manuals and technical documents over at the vintagemachinery site… they should have the adjustment and alignment procedures for your machine.
McFly
#2 posted 11-20-2015 12:03 AM
Yep, it’s a 900.
Time to RTFM
McFly
#3 posted 11-20-2015 12:03 AM
Yep, it’s a 900.
McFly
#4 posted 11-21-2015 10:21 AM
Found it. That was easy peasy like a little lemon squeezy.
View Daruc's profile
Daruc
460 posts in 1157 days
#5 posted 11-21-2015 03:06 PM
