Table saw sled runner
Forum topic by CecilD posted 11-19-2015 03:35 AM 1083 views 0 times favorited 4 replies Add to Favorites Watch
View CecilD's profile
CecilD
53 posts in 3304 days
11-19-2015 03:35 AM
Has any one used HDPE for runners on a sled? Any advantage over wood?
View Rick_M's profile
Rick_M
10851 posts in 2257 days
#1 posted 11-19-2015 03:40 AM
You mean besides less friction and not susceptible to changes in humidity? None at all.
-- http://thewoodknack.blogspot.com/
View HokieKen's profile
HokieKen
4595 posts in 1015 days
#2 posted 11-19-2015 04:00 AM
Rick is right. You just have to make sure you use enough screws to prevent deflection and that your screws don’t cause it to bulge. It’s probably a good idea to capture it in a dado for the same reasons.
-- Kenny, SW VA, Go Hokies!!!
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 1987 days
#3 posted 11-19-2015 08:55 PM
I’ve used HDPE, but greatly prefer 1/4” birch ply.
Ply is super stable, tough end grain is your bearing surface, and the end grain holds wax. Your runners do not need to go all the way to the bottom of the slot, as your slots have the sides relieved below 1/4”...
If you look closely, your slots probably look like this:
Note that there isn’t anything to ride against at the bottom of the sides…
The other beauty of plywood is that you can place the runners in the waxed slots, apply glue, weight down the sled floor, and you’ll have perfectly aligned runners. Once the glue sets, simply flip the tool over and add a few screws. Great sleds in minutes of actual work….
View SirIrb's profile
SirIrb
1239 posts in 1107 days
#4 posted 11-19-2015 11:34 PM
It’s slicker. Though I believe it was delrin I used. I love delrin. Great plastic.
