PC 4212 Porter Cable Dovetail Jig - what size Guide Bushing to use?
Forum topic by woodworm posted 12-27-2009 03:13 PM 8650 views 0 times favorited 4 replies Add to Favorites Watch
View woodworm's profile
14458 posts in 3526 days
12-27-2009 03:13 PM
Topic tags/keywords: pc 4212 dovetail jig question guide bushing size
Hil all,
First I would say sorry for bothering you all with this simple question. I’ve been of searching this info on the internet, but could not find one.
I bought this jig in 2007, used once for just a test cut. I do not have project that requres me to use this jig. Now I plan to use it but couldn’t locate the guide bushing (PC guide bushing) supplied with the jig.
However I own 9-piece brass guide bushing kit bought at MLCS, but not sure which one to use for this jig.
So can anyone reconfirm these bits I’m having can be used with this jig and also the size of the Guide Bushing to be used.
PC 4212 – Standard Template – 17/32”D 7 degree Dovetail bit – 13/32”D Straight bit
PC 4215 – Miniature Template – 9/32”D 7 degree Dovetail bit – 3/16”D Straight bit
Question : What’s the size of the Guide Bushing to use and does it fit both templates?
Thank you,
P/S – and how to type the symbol for degree? sorry I do not have master either…LOL
-- masrol, kuala lumpur, MY.
16273 posts in 4154 days
#1 posted 12-27-2009 04:13 PM
I have the same jig. I’m not sure of the size, but all you need to do is find a bushing that fits between the teeth of the standard template without being loose.
View bluchz's profile
187 posts in 3309 days
#2 posted 12-27-2009 04:34 PM
If you check the PC website it lists the 2 guide bushings that come with that model Dovetail machine. One is a 3/4” and the other is a 5/8” Here is a link to the owners manual for that Dovetail jig.,4210%204212.pdf
It’s long about 44 pages but the info is probably in there somewhere.
-- flash=250,100][/flash]
View ajosephg's profile
1880 posts in 3497 days
#3 posted 12-27-2009 06:13 PM
To expand on what bluchz said -
My PC 4212 has 2 templates.
The half blind & sliding dovetail template requires a bushing with an outside diameter of 3/4” – Porter Cable P/N 42040..
The Through and box template requires two bushings. One with an outside diameter of 3/4” to make box joints, and one with an outside diameter of 5/8” to make through dovetails – Porter Cable P/N 42047.
I also have a Miniature Dovetail/Box Joint template that requires a bushing with an outside diameter of 3/8” – Porter Cable P/N 42037.
For whatever reason, Porter Cable in their infinite wisdom does not cross reference jig part numbers to bushings and bits in their owners manual.
By the way – After market guide bushings will not work if the height of the bushing exceeds the template thickness – nominally 1/4”.
-- Joe
#4 posted 12-27-2009 06:59 PM
Thanks everyone.
I’ve saved the supplementary manual for future reference and c&P the above replies.
Thank you!
