Workbench Design Review
Forum topic by PedroL posted 11-17-2015 08:30 PM 933 views 0 times favorited 10 replies Add to Favorites Watch
View PedroL's profile
PedroL
8 posts in 946 days
11-17-2015 08:30 PM
I have been wanting to build a new workbench that will butt up to my existing workbench to total a 4’ x 8’ work space / off cut support for my table saw. Seeking constructive feedback for my initial Sketchup design.
10 replies so far
View Tedstor's profile
Tedstor
1643 posts in 2657 days
#1 posted 11-17-2015 08:50 PM
Seems like it would work. You might add a stretcher toward the top of the legs OR just add a piece of 1/4” ply to the legs and make a torsion box. Better yet, use pegboard…..then you can hang tools and such.
PedroL
8 posts in 946 days
#2 posted 11-17-2015 08:54 PM
Interestingly the photo is not displayed completely.
PedroL
8 posts in 946 days
#3 posted 11-17-2015 08:58 PM
There fixed the photo to show the full bench with the cutout for the table saw and where it will but up to the existing bench.
View cajunworkshop's profile
cajunworkshop
64 posts in 1019 days
#4 posted 11-18-2015 08:19 AM
I had a similar idea on a bench I want to build like this. I gave a 10 inch contractors table saw and wanted to build a u shape bench that would slide around the table saw. I thought of having a design where I could place a table top in the u shape cut off when not in use with the table saw. Anyone else done something like this?
-- Cajun Workshop Greenville, SC
View conifur's profile
conifur
955 posts in 1175 days
#5 posted 11-18-2015 09:00 AM
I think it is a personal thing, but if the saw is where I think it is the bench acts like an out feed table? But all has to cleared off the WB when doing that.,it would not be my choice. I guess it is about space you have, and size of sheet goods being cut. I personally would not work for me and my shop is 15’x15’ I have a out feed table for my TS, and if I am doing something with 4×8’ sheet goods I break it down to rough size in the garage b4 bringing to the basement shop for final sizing, same with something that is lets say 6” x 8’ but need a few shorter lengths out of it.
View InstantSiv's profile
InstantSiv
262 posts in 1619 days
#6 posted 11-18-2015 01:13 PM
Very interesting design! I like the simplicity of the bottom portion(where the casters are attached.)
My only critique is it might be structurally weak if you put force on it along the green axis. I don’t know what joints and dimensions you have planned… so it might not even be an issue.
View bondogaposis's profile
bondogaposis
4759 posts in 2375 days
#7 posted 11-18-2015 01:38 PM
I would be worried about the flexibility of the top I would add stretchers, all the way around the top to increase the stiffness.
-- Bondo Gaposis
PedroL
8 posts in 946 days
#8 posted 11-18-2015 02:32 PM
Thanks for the advice. It was just what I was looking for. I think stretchers across the way to go.
The dimensions of the table will be 4’x8’. Thinking two 3/4” sheets of ply of MDF for the top. 2×6’s for everything else and 4” casters. The L shaped cut out is 20” x 60” to fit my existing bench. The U or C shaped cut of will be for the table saw and it 25 3/4” x 17 5/8” . Pocket holes are the current plan for construction.
The minimal leg support is so I can figure out a way to also have the dust collection stored in the space directly behind the table saw (if not a vacuum at least a box directly under the saw).
View waho6o9's profile
waho6o9
8207 posts in 2601 days
#9 posted 11-18-2015 02:41 PM
I was thinking the cut out could be a route table, but adjoining it to an
existing bench makes senses as well.
Not sure if you’re aware of Rpn Paulks’ workbench so this might give you some additional
ideas.
PedroL
8 posts in 946 days
#10 posted 11-18-2015 04:28 PM
That Rpn Paulks’ workbench is nice. I also plan to add dog holes and miter slots and T-tracks to mine. I’ve add the stretchers and flipped it over to show the underside. Unless anyone sees any structural issues I may call the ‘frame and top” portion of the design done and move on to how I will make the dust collection be stored underneath.
