HELP! Planer screw stuck...
Forum topic by BoomWood posted 11-17-2015 07:59 PM 624 views 0 times favorited 6 replies Add to Favorites Watch
View BoomWood's profile
BoomWood
44 posts in 875 days
11-17-2015 07:59 PM
(Ridgid R4331)
So I was able to get all the screws out of the three blades except for one. This one screw is stuck – the head is somewhat stripped so the wrench that it came with isn’t able to pull it out.
I’ve tried pliers and vice grips.
I would like to avoid sending this whole thing out for just a screw – is there anything else I can do to get this screw out? I’d hate to lose the planer for a few days or weeks…
Thanks!
View distrbd's profile
distrbd
2252 posts in 2317 days
#1 posted 11-17-2015 08:18 PM
Could you apply some heat to it ? I once used a BBQ lighter to put the flame right on the bolt and it did loosen up .
-- Ken from Ontario, Canada
View Redoak49's profile
Redoak49
3003 posts in 1859 days
#2 posted 11-17-2015 08:25 PM
This was a common problem with DeWalt planners and you could do a search for those.
On my planer, I drilled the head of the bolts off, took the blade off and then the screw came out easy. You could also use a Dremel tool to cut the head off. People have used these techniques successfully.
View WhyMe's profile
WhyMe
934 posts in 1432 days
#3 posted 11-17-2015 10:08 PM
Try giving the screw a slight hit with a small flat tip punch in the hole of the screw head. I had a few screws on my Dewalt loosen up after a whack. I replaced all the allen head screws with torx head.
BoomWood
#4 posted 11-18-2015 02:06 AM
Thank you for the suggestions guys…but nothing worked. Dropped off the planer at the service center. It’s gonna be a long week.
BoomWood
#5 posted 11-18-2015 02:41 AM
View Mojo1's profile
Mojo1
260 posts in 2561 days
#6 posted 11-23-2015 08:39 PM
I drilled mine out ,like redoak, I had about 8 stuck screws.
