How to sharpen a saw
« back to Coffee Lounge forum
Forum topic by sharad posted 1239 days ago 704 views 1 time favorited 6 replies Add to Favorites Watch
View sharad's profile
sharad
1059 posts in 1970 days
1239 days ago
Topic tags/keywords: humor question
This is what I found on the web site eHow. Has anyone used round files for sharpening a saw?
Sharad
How to Sharpen a Saw Contributor
By eHow Contributing Writer
Article Rating: (20 Ratings)
Although saws are tedious to sharpen, you don’t need to do it more than once per season, and the time spent will make your cutting chores much easier. You need a round file and a vice – and of course, a dull saw.
Things You’ll Need:
• Linseed Oils
• Lubricating Oils
• Round Files
• Vises
1. Step 1
Lock the saw blade into the jaws of a bench vice, teeth pointing up.
2. Step 2
Use a round file to sharpen each individual tooth. The teeth have a beveled side and a straight side; sharpen the beveled side.
3. Step 3
Run the round file between the teeth to sharpen. You should see a new, shiny edge as each tooth becomes sharp.
4. Step 4
Continue sharpening the teeth until you have done them all.
5. Step 5
Turn the saw over in the vice and sharpen all the teeth on the other side of the blade.
6. Step 6
Spray the blade of the saw with a light lubricating oil to preserve the finish and prevent rust.
7. Step 7
Coat the wooden handle with a light coat of linseed oil.
-- “If someone feels that they had never made a mistake in their life, then it means they have never tried a new thing in their life”.-Albert Einstein
View Woodwrecker's profile
Woodwrecker
3005 posts in 1741 days
#1 posted 1239 days ago
Thank you very much Sharad.
-- Eric
View Tim Pletcher's profile
Tim Pletcher
88 posts in 1239 days
#2 posted 1238 days ago
Thank you, but I’m still not sure that I’m going to attempt it …again ;)
-- http://plasticlumber.timpletcher.com/
86943 posts in 1743 days
#3 posted 1238 days ago
Thanks alot Sharad
View FJPetruso's profile
FJPetruso
285 posts in 1875 days
#4 posted 1238 days ago
I guess that another key to getting the saw sharpened correctly would be to also have a file that’s the right size for the teeth of the saw that you are sharpening. Thanks for the info Sharad.
-- Frank, Florissant, Missouri "The New Show-Me Woodshop"
View Julian's profile
Julian
880 posts in 1691 days
#5 posted 1238 days ago
A round file wouldn’t do much good for most handsaws. All mine need triangle style files to sharpen or cut new teeth.
-- Julian, Park Forest, IL
teenagewoodworker
2727 posts in 1934 days
#6 posted 1238 days ago
yeah that would have to be a pretty big handsaw. maybe theyre talking more of a tree branch saw. i have one of those ant they have curved teeth. other than that triangular saws all the way
